Old 02-19-2023, 07:33 PM   #1
AnthonyG
AnthonyG's Avatar
Default Antifreezes
Hi all, with all the hi-tech antifreezes out there has anyone tried this, Zerex Dex-Cool organic acid Tech. Supposed to be great on corrosion protection of aluminum & rust on iron.
Nomad
AnthonyG is offline   Reply With Quote
Old 02-19-2023, 10:57 PM   #2
40 Deluxe
Default Re: Antifreezes
Have you ever seen the sludge build-up in a Dex-Cool system? They can get downright nasty! GM even put out a special video on how to deal with this.
You need a sealed system-one with a recovery bottle and you need to keep the bottle full enough so no air is drawn in when the engine cools down. And a particular style cap is used, having to do with the little vent valve on the bottom of the cap. I forget all the details on how to keep the cooling system clean with Dex-Cool; been too many years. Talk to a GM tech if you know one.
Old 02-20-2023, 07:29 AM   #3
corvette8n
corvette8n's Avatar
I didn’t know there were so many kinds of antifreeze until I changed the radiator out in my wife’s Toyota, here’s what I found online.
There are three types of antifreeze available: Inorganic Acid Technology (IAT), Organic Acid Technology (OAT), and Hybrid Organic Acid Technology (HOAT).
IAT is mainly used in older vehicles, is usually bright green, and has to be replaced every 30,000 miles.
OAT antifreeze/coolant is usually orange, yellow, red, or purple, and lasts much longer — 150,000 miles — but doesn’t contain any silicates or phosphates for additional engine protection.
HOAT antifreeze/coolant is typically orange or yellow and can last for 150,000 miles
Old 02-20-2023, 09:42 AM   #4
5851a
I have 3 newer vehicles, all 3 take a different type and all 3 have been superseded by a new spec more than once. It's very hard to keep up with the changes. All the older cars take the same green. That's way easier to handle.
5851a is offline   Reply With Quote
Old 02-20-2023, 10:24 AM   #5
oldbugger
oldbugger's Avatar
maybe im just putting my head in the sand, but i put the good old green in everything i have and have had no issues
oldbugger is offline   Reply With Quote
Old 02-20-2023, 11:17 AM   #6
qmdv
qmdv's Avatar
But if you use concentrate and not the premix use distilled water. I did not one time and had a lot of corrosion on my aluminum heads. We have rally hard water. Learned the lesson
qmdv is offline   Reply With Quote
Old 02-20-2023, 12:27 PM   #7
AnthonyG
AnthonyG's Avatar
I’ll go with the good ole green!
Nomad
Old 02-20-2023, 01:29 PM   #8
AnthonyG
AnthonyG's Avatar
Any tips on easy way to get all coolant out of a my ‘35
Nomad
Old 02-20-2023, 02:31 PM   #9
joe 1950
joe 1950's Avatar
i’ve been using the good old yellow prestone for over 35 years and never had a problem with in my 50 willy’s jeep 31model A. 1950 Ford i buy the coolant without water i mix my own soft water
joe 1950 is offline   Reply With Quote
Old 02-20-2023, 03:41 PM   #10
AnthonyG
AnthonyG's Avatar
Smile Re: Antifreezes
Took 4 1/2 gal’s seems right as I don’t have a heater in the car. I think 5 gal or so is what it’s supposed to take. Seems pretty close. Took out for a ride w coolant about 1/2” from top of tank, stayed around 180-190 & nothing came out of the over fill / over heat blow by tube or what ever it’s called.
Great Late January & all of February in Stroudsburg Pa. Lots of days in the 50s-60s! Had all the toys a lot this mild winter!:
Nomad
Old 02-20-2023, 07:20 PM   #11
oldbugger
oldbugger's Avatar
My 35 stays about an inch above the cores when its 80 deg, stays under 195 in slow traffic . 4 1/2 gallons sounds about right
Old 02-21-2023, 05:23 PM   #12
AnthonyG
AnthonyG's Avatar
Thx for confirmation Oldbugger!
Nomad
Old 02-22-2023, 04:09 PM   #13
flathead4rd
flathead4rd's Avatar
I use Sierra and distilled water in my 50. Mix it half & half. Been using it for 20 yrs and it gets cold here in the winter. Sometimes as much as 20 below zero. What I like about Sierra is it is non toxic to animals.
flathead4rd is offline   Reply With Quote
Old 02-22-2023, 06:05 PM   #14
Tim Ayers
Not to sound like a broken record, but when this comes up, I always post about No-Rosion.
https://www.no-rosion.com/norosioncoolant.htm
When used with purified (not distilled) water, it provides excellent corrosion prevention when using aluminum heads. If using only water, only snag is you'll need to drain it over the winter if you live somewhere that gets cold enough.
No-Rosion can be used with antifreeze as well.
Even if you don't use their products, there are numerous good articles to read about cooling and various products.
Old 02-23-2023, 10:37 AM   #15
flatford8
flatford8's Avatar
Over the last 5yrs or so I’ve done anti-freeze changes 4 or 5 times in a couple of older vehicles and a stationary engine. I buy the green prestone concentrate and mix 50/50 with distilled water. I’m very careful to get the mixture right and 3 times the level of protection wasn’t down to the -35* that the chart on the back of the jug said it would be.
My point is, you really need to test it after it’s mixed and the engine has been brought up to temp…….Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
