Old 01-13-2023, 09:22 PM   #1
JayJay
Default Starter removal issue
In preparation for removing the steering column from my ‘31 s/w sedan, I had to pull the starter. Turns out that the previous owner had installed a “modern” Bendix drive, and the head of it was so large that I couldn’t get it past the flywheel ring gear without removing the water inlet ( lower gooseneck). Which of course meant draining the coolant… what a PITA! Has anyone run into this before? I can see where this would make working on the starter at the side of the road into a major undertaking.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 01-13-2023, 09:44 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Starter removal issue
Yes. One of the reasons I went back to the stock bendix.
Old 01-13-2023, 09:50 PM   #3
31a
Just did this has to be done. Not too bad good luck
31a is offline   Reply With Quote
Old 01-13-2023, 10:11 PM   #4
Bill G
Bill G's Avatar
Wah wah. Have you tried changing the starter on your average modern car? Just saying....
Bill G is offline   Reply With Quote
Old 01-13-2023, 10:21 PM   #5
quickchange
quickchange's Avatar
No problem on RHD,
quickchange is offline   Reply With Quote
Old 01-13-2023, 10:42 PM   #6
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I have removed starters with a modern bendix numerous times. Never had to remove coolant hose. Just have to maneuver the bendix gear around the flywheel. Just takes a few more seconds than the stock bendix.
Ivan in southeast va. is offline   Reply With Quote
Old 01-14-2023, 06:55 AM   #7
jack backer
If you have an f100 steering box you have to pull the water inlet to get the starter out.
By the side of the road? Don’t you carry a crank?
jack backer is offline   Reply With Quote
Old 01-14-2023, 07:53 AM   #8
jw hash
jw hash's Avatar
I`m with Chuck. I run a V8 bendex,
jw hash is offline   Reply With Quote
Old 01-14-2023, 01:15 PM   #9
nkaminar
nkaminar's Avatar
I have the F 100 box and the modern Bendix and have managed to remove the starter with some gymnastics without removing the water inlet.
Old 01-14-2023, 05:02 PM   #10
Herb Concord Ca
This is an "old wives' tale". I agree with #6 and #9. It can be done.
Herb Concord Ca is offline   Reply With Quote
