Old 12-18-2022, 11:17 AM   #1
38convsedan
38convsedan's Avatar
Default 8BA upper carb gasket wet/won’t run without choke
Chasing down issue on newly rebuilt 8BA
Won’t idle without choke, upper carb gasket wet with fuel
Have to set idle screw almost all the way open to get idle with choke open
Previous owner did rebuild/never could get engine running properly
38convsedan is offline   Reply With Quote
Old 12-18-2022, 11:21 AM   #2
Mart
Mart's Avatar
Default Re: 8BA upper carb gasket wet/won’t run without choke
What sort of carb do you have on it?
Old 12-18-2022, 11:21 AM   #3
38 coupe
38 coupe's Avatar
Something is wrong in your idle circuit. I suggest taking the carburetor apart again and verifying all the little passages are open. Compressed air and tiny soft brass wires (a single strand from a multi-strand wire) are your friends for cleaning passages.
Old 12-18-2022, 11:29 AM   #4
joe 1950
joe 1950's Avatar
the upper gsk showing signs of wetness is somewhat normal if it’s dripping fuel then there’s a float problem or needle and seat but either way it needs to come apart like 38 coupe suggested good luck
joe 1950 is offline   Reply With Quote
Old 12-18-2022, 12:13 PM   #5
38convsedan
Carb is a model 8BA
I’ve never torn down/cleaned/rebuilt a carb and am hesitant to screw things up
Old 12-18-2022, 12:28 PM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
Send it to Charlie then…….. and then you’ll be done.
1948F-1Pickup is offline   Reply With Quote
Old 12-18-2022, 06:09 PM   #7
38convsedan
Complicating matters is that I’m unsure timing is correct. When I set timing just BTDC, car backfires and is difficult to start.
I’m in search of ground zero!
Old 12-18-2022, 08:34 PM   #8
tubman
tubman's Avatar
Originally Posted by 38convsedan View Post
Complicating maters is that I’m unsure timing is correct. When I st timing just BTDC, car backfires and is difficult to start.
Remember, The "dot" on the front pulley is already at 4 degrees BTDC. Set it right on the dot, not before it.
Old 12-19-2022, 07:26 AM   #9
Terry,OH
Terry,OH's Avatar
The Carb has three idle adjustments. One for RPM and two are for the fuel air mixture adjustment. These three only effect idle. Suggest you leave both of the mixture adjustments about 7/8 of one turn out. The engine should idle with this setting unless the RPM setting is too low. This setting can be fine tuned later.
Old 12-19-2022, 08:00 AM   #10
rockfla
rockfla's Avatar
38ConvSedan
I am up in Jax, "maybe" I can make a Saturday trip IF you need??? Your just far enough to be close OR just close enough to be far not sure which......I don't have any 8BA stuff already done, IF it was 38 stock, I have a distributor already done and set by Michael at Third Gen and carburetor already done by CHarlieNY we could plug and play!!! PM me IF you need.
Old 12-20-2022, 04:48 PM   #11
38convsedan
PROBLEM SOLVED!!
It was a carburetor issue.
1). Vacuum advance fitting was leaking at carb (engine smoothed out when spraying carb cleaner at that fitting). Reinstalled fitting correctly.
2). Noticed passenger side idle screw setting made no difference, including removing it completely. Blew out opening and sprayed carb cleaner…
Engine now runs great!!! It has never run this well in all the time I’ve owned it.
Thank you to all who helped out!!!
