12-23-2010, 11:43 PM | #1 |
Wood graining (revisited )
Hi guy's I think I have found a local artist do some Woodgraining. He asked me for a clear picture how it looks like . Could one of you of post me a picture of mahogany grain on a dashrail or Garnish ?? Thanks in advance.
12-24-2010, 07:27 AM | #2 |
Re: Wood graining (revisited )
Two suggestions, ....
A) Visualize the metal piece (Dash rail, window frame, gardnish, etc.) as if it were carved out of a block of Mahogany. The grain would run horizontal and how would it look in the corners and curves? B) Look on the internet for a JPEG that shows a large plank of Mahogany board which will allow your artist to visualize the grain. Are you going to do the prep & post work on your items or is the artist going to do everything? . |
12-24-2010, 08:20 AM | #3 |
Hi Brent, The local Artist is doing everything ( he told me ) I think I have a chunk of Mahogany somewere in the attick , good idee !! Thanks . Will let him make a sample first to see how his work is.
Happy Holliday's |
12-24-2010, 08:22 AM | #4 | |
12-24-2010, 08:33 AM | #5 |
Gerard and Brent, Go to Brent's excellent site. Click on "Restorations". When the page comes up, you will see some of the work Brent's done. You will see a Maroon 31 TS. Clck on it. There are a couple of pics showing the woodgrained dash. They give you an idea what it should look like. The color is kind of "orangey" for me, but it's no problem to use a darker mahogany. Now, Where do you get a large diameter silicon roller? Or silicon to make the roller?
Terry |
12-24-2010, 09:23 AM | #6 |
12-24-2010, 09:35 AM | #7 |
dag nab it. forgot pix again
12-24-2010, 09:46 AM | #8 |
Thanks Ken, perfect job !!!!!!!!!!!!!!!
12-24-2010, 09:59 AM | #9 |
I looked up the URL for "Grain-It Technology". Neat stuff!!
http://woodgraining.com/
Alan 1930 Cabriolet (the newest project) 1929 Special Coupe (pieces n parts) 1928 Sport Coupe (the driver) |
12-24-2010, 12:18 PM | #10 |
Registered User
here are a few shots of an original woodgrained dash
the colors dont show correct,it is actually browner rather than redder but you can see the graining good Ken Parkers dash is beautiful tom |
12-24-2010, 12:29 PM | #11 |
12-24-2010, 02:33 PM | #12 |
Thanks Guys.
12-24-2010, 03:22 PM | #13 |
There seems to be two essential ways to woodgraining. 1) painting the grain over the base coat with a coarse bristle brush 2) Painting the grain on the base coat with a roller. The roller method requires a graining plate that is sort a mirror image of the grain. You inkthe plates with the darker color and roll it onto to roller, then roll it onto the part. I'm thinking of trying to make a "Graining plate" out of a piece wood scrap that has been roughed up with a coarse wire wheel. This is a one shot deal, I'm not going into the woodgraining business.
Terry |
03-08-2011, 12:27 AM | #14 |
Try sand blasting your wood piece, maybe block sand to fine tune the surface... Karl
03-08-2011, 01:14 AM | #15 |
My problems ( with the woodgraining )are solved grin grin
03-08-2011, 07:11 AM | #16 |
Which kit from grain it tech did you use? I get a little confused when I start looking at their products.
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
03-08-2011, 07:22 AM | #17 |
jamie, I found a local artist who was willing to help out after some experimenting he found a way to it . I paid him 500,-- for the job and I am very pleased .
03-08-2011, 01:36 PM | #18 |
Here are a couple of great shots of Stipple Mahogany
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
03-09-2011, 09:09 AM | #19 |
Jamie, you asked which kit did I use - from Grain It Technology. I bought it when at the Workshop at Brents Shop two years ago. At the time it was the only style kit he/she had with them. All I 'member is it is original style short grain mahogany version. The base coat they had with the kit had too much brown in it, so i went to my local paint supplier (PPG) and had them mix something with a little more red in it. I will have to do some research to find the formula PPG used to make that formula of base coat.
03-09-2011, 09:38 AM | #20 | |
