01-13-2023, 09:22 PM | #1 |
Starter removal issue
In preparation for removing the steering column from my ‘31 s/w sedan, I had to pull the starter. Turns out that the previous owner had installed a “modern” Bendix drive, and the head of it was so large that I couldn’t get it past the flywheel ring gear without removing the water inlet ( lower gooseneck). Which of course meant draining the coolant… what a PITA! Has anyone run into this before? I can see where this would make working on the starter at the side of the road into a major undertaking.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
01-13-2023, 09:44 PM | #2 |
Re: Starter removal issue
Yes. One of the reasons I went back to the stock bendix.
01-13-2023, 09:50 PM | #3 |
Just did this has to be done. Not too bad good luck
01-13-2023, 10:11 PM | #4 |
Wah wah. Have you tried changing the starter on your average modern car? Just saying....
01-13-2023, 10:21 PM | #5 |
No problem on RHD,
01-13-2023, 10:42 PM | #6 |
01-14-2023, 06:55 AM | #7 |
If you have an f100 steering box you have to pull the water inlet to get the starter out.
By the side of the road? Don’t you carry a crank? |
01-14-2023, 07:53 AM | #8 |
I`m with Chuck. I run a V8 bendex,
01-14-2023, 01:15 PM | #9 |
I have the F 100 box and the modern Bendix and have managed to remove the starter with some gymnastics without removing the water inlet.
01-14-2023, 05:02 PM | #10 |
This is an "old wives' tale". I agree with #6 and #9. It can be done.
