Old 03-26-2020, 03:01 PM   #1
billfish
billfish's Avatar
Default gear ratio
looking for a way to lower the RPM at cruising speed by changing the stock differential gear ratio on my friends 1951 ford convertible. It's powered by a 302 with C4 auto trans with no overdrive. With the stock rear at 3.9 gear ratio it runs 3,000 RPM's at 50 miles an hour. He's not interested in quick starts just a smother ride at cruising speeds.
Is this something that can is done or can be done reasonably without going for a new transmission with overdrive?
billfish is offline   Reply With Quote
Old 03-26-2020, 03:07 PM   #2
JSeery
JSeery's Avatar
Default Re: gear ratio
Look at a speed vs rpm calculator. You can change tire size or rear axle ratio.
Old 03-26-2020, 03:14 PM   #3
42merc
42merc's Avatar
I believe the rear gear from an automatic trans car is about a 3:30 ish.
That's about the best your gonna' do with out an overdrive.
42merc is offline   Reply With Quote
Old 03-26-2020, 03:37 PM   #4
Alaska Jim
Alaska Jim's Avatar
What 42Merc says , is probably the easiest and best way to achieve your goal. I think that the 49-51 Ford had a drop out center , If you can find a used rear diff, or just the drop out center from one of these that was originally an automatic car, I believe the rear ratio was 3:31. If I am wrong about the 49-51 Fords having the drop out, I know the 52-53 Fords did, as I have changed many center sections on those. The whole Diff may be able to be swapped in, but you would have to measure to be sure. I have not worked on one of these early Fords for over 30 years, and none around here to look at and check for you. good luck.---Jim
Alaska Jim is offline   Reply With Quote
Old 03-26-2020, 03:37 PM   #5
toby
toby's Avatar
I have instructions on how to put in a 70's V8 Maverick or Comet automatic rear end in a Shoebox. It would give you a rear end ratio of 2.79. The standard tranny rear end would be a 3.00. The V8's have a 5 on 4 1/2 bolt pattern. email me at [email protected]. I can send it email or snail mail.
Toby.
toby is offline   Reply With Quote
Old 03-26-2020, 04:26 PM   #6
flatford8
flatford8's Avatar
There’s a company that advertises in Hemings that has automatic ratio rears for ‘49- ‘51 cars . It is a drop out center section so changing would be easy. If you want that info I’ll send it to you tonite...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
flatford8 is online now   Reply With Quote
Old 03-26-2020, 04:35 PM   #7
solidaxle
solidaxle's Avatar
Here's from Rumble seat. Boy he new his stuff.
solidaxle is offline   Reply With Quote
Old 03-26-2020, 07:56 PM   #8
flatford8
flatford8's Avatar
The ad lists over fifty 49-50-51 cars he’s parting out. For an automatic rear it would need to be a ‘51. Contact info is: Chris 610-442-2187 afternoon, PA.
Im going to post this on your thread too, for others.
Billy Joe Shaver
Old 03-26-2020, 10:25 PM   #9
Alaska Jim
Alaska Jim's Avatar
flatford8, Thanks for pointing that out about the rear for an automatic having to be from a '51. I forgot that that was the first year for the automatic.
Old 03-27-2020, 10:27 AM   #10
deuce5wndw
deuce5wndw's Avatar
1951-55 automatic cars are the same except station wagon and sedan delivery. 3:30 ratio
deuce5wndw is offline   Reply With Quote
Old 03-27-2020, 10:46 AM   #11
50fordcoupeman
50fordcoupeman's Avatar
Deuce is correct. My avatar has a '55 Ford rear end in it. The rpms dropped by 1000 at 60mph from 4:11s that was in it.
50fordcoupeman is offline   Reply With Quote
Old 03-27-2020, 12:21 PM   #12
billfish
billfish's Avatar
Thanks to all for the good information--I'll check into the 51 to 55 rear.
Old 03-27-2020, 03:53 PM   #13
KGS
KGS's Avatar
If you happen to find a '55 or '56 Ford pumpkin that you want to use, make sure you get the axles that go with it. I know in '56 the splines on the axles have a different count than the '51 and I suspect that '55 is the same situation. The "56 axles are the same length as the '51 so the '56 axle/pumpkin combo will fit the '51 housing with no problem.
Ken
KGS is offline   Reply With Quote
Old 03-27-2020, 07:10 PM   #14
Ol' Ron
Ol' Ron's Avatar
I used a78 ford rear from a C4 car in the junkyard. It had 3.07 ratio. I used it in a 52 PU with a 302 and c4 cruise was in the mid 2k around 65/70. It was practically a bolt in.
Old 03-29-2020, 12:18 AM   #15
dwollam
dwollam's Avatar
I put 1954 Ford 3.54 center section and axles in my '51 coupe many many years ago. '54 had the finer spline axle so both center section and axles had to change.
Dave
dwollam is offline   Reply With Quote
