Old 01-16-2018, 11:14 AM   #1
deuce5wndw
deuce5wndw's Avatar
Default Split valve guide question
Are the split valve guides machined as pairs or are they machined close enough to mismatch the halves? Reason I ask I was digging out some NOS flathead parts in an old warehouse and found a set of 60 hp guides but they had fell out of the box and lay in a pile! Thanks in advance for your help, Dale.
deuce5wndw is offline   Reply With Quote
Old 01-16-2018, 11:41 AM   #2
JSeery
JSeery's Avatar
Default Re: Split valve guide question
Believe they are matched pairs, but not 100% positive. You might be able to match them up with some careful measuring.
Old 01-16-2018, 01:25 PM   #3
Karl Wolf
Karl Wolf's Avatar
I would plug fit them, wiggle the valve to check for clearance.
IMO, there are too many things- places- to measure.
Karl...
Karl Wolf is offline   Reply With Quote
Old 01-16-2018, 08:08 PM   #4
v8fordman
v8fordman's Avatar
If you pay attention to the machining marks and the notches where the valve installation bar goes, you should be able to match them up. It will take you some time.
v8fordman is offline   Reply With Quote
Old 01-16-2018, 08:41 PM   #5
Talkwrench
Talkwrench's Avatar
Ohhh jigsaw puzzle....
Old 01-16-2018, 09:27 PM   #6
Ol' Ron
Ol' Ron's Avatar
Their interchangable, but I;d never use them. Convert to the soli dguides and valves.
Old 01-17-2018, 01:46 AM   #7
hardtimes
hardtimes's Avatar
I agree with your Ron !
The 'modern' set is easier to use and less hassle and consistent fitment.
Old 01-17-2018, 09:00 AM   #8
deuce5wndw
deuce5wndw's Avatar
Thanks guys. I agree with Ron also but these are for a 60 hp and I don't think Ford made the solid guides for a 60 did they? Dale
Old 01-17-2018, 10:22 AM   #9
Ol' Ron
Ol' Ron's Avatar
Yes, the 60 never had a solid guide. I made a set for a fellow many years ago, using 1/4 valve stems. Can't remember where the valves came from. I understand ths was a common practice with the midget racers.
