05-03-2020, 09:56 AM | #1 |
Model 59 Carb too small?
Is this carb to small for a 255 motor with a L100B cam (.369 lift)?
I wanted to use this carb to break the motor in before I put the blower back on. |
05-03-2020, 10:00 AM | #2 |
Re: Model 59 Carb too small?
It may be slightly less horse power at high rpm than the slightly larger 255 Merc carb, but plenty good to break in a motor, or even use as is.
Sal |
05-03-2020, 10:02 AM | #3 |
Yes, The amount of venturie area is determined by the displacement and rpm of the engine. owever, the smaller carb will givr good throttle response in th low to misrange RPM for a street engine. One question, What's an L100B cam?? How much duration? Same as the L-100? Who makes it?
05-03-2020, 10:28 AM | #4 |
I had it ground by Kiwi! Here's what he posted:
The L100 cam had become quite "Notorious" over the last many years with Flathead lovers . Some call it the "SmileyCam" because of its real racey hot rod sound. Originally ground I believe by the "Literio Bros" from the North East some called "The Isky" of the east. Flathead Legend "Ol Ron" Holeran has one in a 5000lb ambulance & also in circle track race cars & reports it pulls strong from down low to 6000+. Many have them in race cars & hot rods all over the world . Reportedly get Decent gas mileage also . Then the were offered by "Cam Techniques" of the Nth East & then Florida until Dave retired . After knowing several people that wanted the L100 I went to work to make the KiWi-L100 once again available to all that want it. The original L100 "Advertised " specs are as follows:- Lift In.=.375 Ex=.375 @ cam Duration @.050 In=246* Ex=238* Lobe centers 111* The blower cam is Lift In. .369 Ex. .368 Duration at .050 In 238* Ex 246* Lobe centers 111* |
05-03-2020, 10:31 AM | #5 |
I just pulled the carb off to see what's inside. It has #51 jets I didn't pull the power valve yet.
Is this a good starting point? My A/F meter is reading lean at idle My biggest problem is I cant get it to idle down! I have to hold it open. It seems the vacuum is trying to close it. Is there anything that could be done about that?? |
05-03-2020, 10:48 AM | #6 |
05-03-2020, 02:42 PM | #7 |
Joe in my opinion you had a combination that worked for you before getting a new engine built. You should put the blower combination on the new motor and then begin tuning. Trying to break in the engine with just a carb no blower is a waste of time. Your not going to do any harm to the new engine with the blower considering if im not mistaken the old set up was working fine. Or an I missing something?
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-03-2020, 02:53 PM | #8 |
You are correct Ronnie! The old set worked great! I figured I could run this for a bit then pull it, check valve adjustment and then put the blower on. If you tell me it’s a waste of time, I know you ain’t lyin’!
05-03-2020, 03:17 PM | #9 | |
By time you will need to look at the valve lash you should have at least a 1000 miles on the car. You have to ask yourself do i want to drive around all that time being bored without the power adder installed. If its me the answer has always been heck no i start the car and drive/tune up with all the options in place that being the power adders..
05-03-2020, 05:17 PM | #10 |
I'm on it! I already started unbolting stuff this afternoon!
05-03-2020, 05:55 PM | #11 |
Boy! I guess I'm the "odd man out" again. I have a known good stock manifold and carb that I use for the initial start of every engine I do. I would never use anything else with a fresh rebuild. If it was a problem to change, I wouldn't think this way, but you don't even have to drain the coolant. A new engine introduces enough new variables.
But, I am not a pro engine builder; if I was doing 10 or 20 engines a year, I might think differently. |
05-03-2020, 06:08 PM | #12 | |
Your first line hit the nail right on the head !
05-03-2020, 07:57 PM | #13 |
Well, I've got a test engine on a stand that I use to check all my distributors and carbs before going on a new build.
