11-01-2013, 08:03 PM | #1 |
Before I do something wrong...
How is the fuzzy stuff fastened to the garnish molding for my 36?
Thanks! Heard
Do I look like I have a plan B? |
11-01-2013, 08:11 PM | #2 |
Re: Before I do something wrong...
I use tape and work around the moulding, bending to fit and taping as I go, then cut to length when I get back to where I started. Then I use a dozen or so spring/hand clamps to glue it using "GOOP", going around and clamping as you go. Go slow and carefully and sparingly with the goop, or it will it get every where you don't want it. Patience, patience. Let it sit over night I've done 2 '36's this way, one six years ago and the fuzz is right where I put it. Good luck. Rod
11-02-2013, 06:29 AM | #3 |
