Old 06-18-2015, 09:35 AM   #1
31Tudor
31Tudor's Avatar
Default 31 Tudor Rear Seat Floor Pan Question?
On the floor pan underneath the rear seat (this is the floor pan with the spring hump on it) it is riveted to the body and subrails. The seat riser is also part of this whole set up. Mine has two screws holding it on, on each inside side of the pan. I would believe that it has never been taken off, because everything looks pretty original on it? so were there 2 screws holding it in place on the sides, or would they have had rivets and been taken out at some time?
31Tudor is offline   Reply With Quote
Old 06-18-2015, 09:57 AM   #2
Jwilli
Jwilli's Avatar
Default Re: 31 Tudor Rear Seat Floor Pan Question?
My 31 tudor had screws.
Jwilli is offline   Reply With Quote
Old 06-18-2015, 09:57 AM   #3
kwisor
kwisor's Avatar
hello
i have 3 screws on each side under the seat riser hard to see in photo's i have a 1930 tudor not sure if that is where you are talking about
kevin
1930 model a tudor
1923 model t roadster p/u
kwisor is offline   Reply With Quote
Old 06-18-2015, 12:51 PM   #4
31Tudor
31Tudor's Avatar
Yep, that looks like the same spot that I am questioning. Thank you!
