03-23-2021, 06:44 PM | #1 |
Ignition Problem or Carb Problem
Went through ignition hell this winter, caused by spiral wound ignition cables with flimsy brass connectors that broke (invisibly) inside rubber boots to the crab distributor, after a few times removing and replacing. Replaced them with copper core wires from Van Pelt. Perfect fit and they look great with the old-school Raja plug connectors.
In spite of Pertronix good advice that their electronic points would not work with copper, due to radio frequency interference with the circuit, I took the Barn person's word who said Pertronix worked fine with solid copper core wires for years. Didn't work so well for me. I got a weak yellow spark for a while and then it croaked. So, went to the Third Gen points distributor, which I always carried as a backup. Started right up, idled fine for a minute, started to get a little rough, chugged, and died. On cranking, it would chug a little but not start. Replaced the coil with the Bosch Blue; got a nice big blue spark, but still chug with no start. By this time the plugs were looking a little black, so I put in a new set of NGK, gapped to a loose 0.025. Now it will start and run for maybe five seconds, and then stumbles to a stop. Acts like it is flooding: Smell of gas. Wet plugs. Pulled the top of of all three 97's expecting to find a sunk float. Nope; they are all shutting flow with the fuel at about 0.5" from the rim. The rear carb bowl seems to evaporate down faster that the other two. Could it be leaking into the manifold? Common with 94 power valve problems, but not so much with the 97's. I raised main jets from .045 to .047 last year. I am maybe too cautious about overtightening the jets. Could one of them have vibrated loose, causing flooding? Ideas? As beautiful as those three chrome plated 97's are on that polished Offy tri-power manifold, they may be more trouble than they are worth. |
03-23-2021, 06:49 PM | #2 | |
Re: Ignition Problem or Carb Problem
Profound ! The Pertronix as well....
03-23-2021, 07:48 PM | #3 |
I’ve had tri-power on my 40 for goin on 25 years and the only problem I’ve had was a couple years ago I experience a small piece of trash inside one of the jets on the primary carburetor.
Feels real good when you stand on it and open up all three. My engine is 3 3/8 bore X 4 1/8 stroke. |
03-23-2021, 08:31 PM | #4 | |
Has anybody had main jets unseat themselves and cause a flooding problem? |
03-23-2021, 10:30 PM | #5 |
Are you running a 6 or 12v system?
03-24-2021, 12:27 AM | #6 |
If the float settings are good, what could cause 97 carbs to flood? |
03-24-2021, 01:47 AM | #7 |
What ohm rating is your coil and do you have a resister in the circuit?
I've found that running a 1.5 ohm coil, with direct 12V, will cause a similar problem. Unless it's puffing out black smoke, when it runs, I don't think it can be the carb.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
03-26-2021, 06:32 PM | #8 | |
Again, after the carb check, it ran at fast idle a little roughly, would not wind up with throttle; started hesitating, then after about five minutes just quit. No black smoke, new plugs not black or wet. I am running a brand new Bosch blue coil which I measured as having very close to 1.5 Ohms. That should not need any other resistor, right? When I set up the new distributor, I put on a new condenser. Could that cause it to run rough and die. The spark from the coil wire is blue and will jump almost half and inch when cranking, but it looks a little thin and puny. And it seems erratic when cranking, like it is not sparking every cylinder. Suggestions? |
03-28-2021, 10:44 PM | #9 | |
With good advice from members of this board, I pulled the Tubman condenser out of the "return" pile and mounted it so it connects to the coil end of the black wire to the distributor, instead of on the distributor itself. Still need an all out road test, but in the garage it is running like a champ! Thought I knew something about flathead ignition. What I did not know is that a nice blue spark when cranking does not necessarily mean that the problem with running rough is in the carburetor. The other thing I learned is, like starter switches, never buy a condenser from just anywhere. |
03-26-2021, 06:52 PM | #10 |
You need about 3-3.5 ohms resistance on a points distributor running 12V. Your coil should get hot running a 1.5 ohm coil with no external resistor on 12V. It should run more than 3-4 minutes, though, in my experience.
Pertronix runs on same coil with no resistor. |
03-26-2021, 09:15 PM | #11 |
So the ballast resistor which I bypassed for the Pertronix needs to go back into the circuit?
03-26-2021, 09:30 PM | #12 |
I've run into the same thing with old Harleys. Electronic ignitions use lower resistance coils than breaker point ignitions. Put the ballast back in and try it.
03-28-2021, 02:48 PM | #13 | |
The bad news is that the engine will still barely run; stumbles; won't take throttle and build up rpm past about 1200. Will swap condensers next. It is not shorted, but if the capacitance is too far off, the mismatch with the inductance of the coil could cause a problem. Will report back when checked out. |
03-26-2021, 11:07 PM | #14 |
The Bosch blue coils I run on a 12v system measure around 3.6 ohms. No resistor needed.
03-27-2021, 09:58 AM | #15 |
I run ,045 mains with #71 PVs in dual 97s on a 221 at 500 feet above sea level. I think .047 is toooo rich. Also connect an ohmmeter to distributor terminal on coil and the other clip to ground and turn engine over by hand with ignition off and see if point resistance goes to zero. Burn points without ballast resistor? I would take a look at the points. Report back.
03-27-2021, 10:11 AM | #16 |
I am having the same problem. I now have the Bosch Blue (internally resisted coil)but will toast points within less than 20 miles. Would like to get this problem solved for sure.
03-27-2021, 11:47 AM | #17 |
Have you ever checked the coil resistance to be sure what it is. I remember something about Bosch knock-offs being out there.
03-27-2021, 11:06 AM | #18 |
That almost sounds like a weak condenser to me.
03-27-2021, 11:11 AM | #19 |
It sounds like the Chinese condensers may be attacking again.
Sal |
03-27-2021, 06:55 PM | #20 |
Tried a different condenser, this one reads .3 mfd. Difficult to find one that reads 3.5. I have a pile of them and all but 2 read about .26 which I understand is not enough. The 2 odd ones, one reads .4 and the other reads .45 which may be too much.
I installed a 1.5 ohm resister in front of the internally resisted Bosh Blue (which reads about 3.0 ohms resistance). These 2 combined helped bring my voltage to the coil down but it may not be enough. I am running a 12 volt neg ground system after the coil I am seeing 8 volts is that still too many amps at the points? |
