08-03-2023, 06:21 PM | #1 |
Can I hone Flathead lifter bores?
I got my block back from the machine shop. It looks like there is a very slight amount of surface rust in the lifter bores. Should I home this with a wheel cylinder hone? Or will that remove too much material?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
08-03-2023, 06:26 PM | #2 |
Re: Can I hone Flathead lifter bores?
Take a rag and wd40- or anything else- to it, I'll bet it goes away.
Karl |
08-03-2023, 06:39 PM | #3 |
^^^^ Yup
Ronnie |
08-03-2023, 08:54 PM | #4 |
round brass wire brush and any lubricant
08-03-2023, 10:33 PM | #5 |
Why bother doing anything about it? The lifters will make short work of any surface rust before the thermostats even open up.
Alan |
08-03-2023, 10:42 PM | #6 |
08-03-2023, 10:55 PM | #7 |
A wheel cyl hone will not remove too much material. You do want a nice clean smooth surface to make sure the lifters rotate freely when they operate, so do what it takes to achieve that. Cleanup after honing is of course of utmost importance.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
08-04-2023, 07:22 AM | #8 |
I ended up running the hone for a very short time through each bore. Cleaning didn’t do enough for me plus but I honed it moreso to make sure there wasn’t a sharp edge from drilling the holes for the adjustable lifters. I maybe did 3 seconds per hole. Just enough to ensure it’s smooth but not really remove any material. I then washed the block for final prep for about an hour. Not sure it could be any cleaner! Thanks y’all.
08-04-2023, 09:54 AM | #9 |
That's perfect. Well done .
08-04-2023, 10:23 AM | #10 |
After I drill all my lifter bores for the lifter adjustment stop. i run a brake cylinder hone thrugh the lifter bore nabd the guide bor to clean them and remove any chips from drilling,
This is another reaon I like to run a 95 Last edited by Ol' Ron; 08-04-2023 at 10:29 AM. |
08-04-2023, 08:32 PM | #11 |
08-04-2023, 02:59 PM | #12 |
3M makes these great Scotch Brite pads that are like a flowers or balls. They go on a standard spindle so you can get into various depths. They are great for they remove rust or small burrs but don't remove material.
08-06-2023, 10:22 AM | #13 |
I thought I wrot 95% oil filter. Just getting old, I guess
G |
08-06-2023, 11:34 AM | #14 |
Thank you for the clarification.
