Old 06-03-2018, 06:47 PM   #1
nhusa
nhusa's Avatar
Default Clutch adjustment
I am adjusting the clutch in my Model A Town Sedan after rebuilding the motor, transmission, and installing a new clutch.
I want to make sure that the throwout bearing does not ride on the clutch fingers.
As I take up the slop in the linkage, I can feel the spring that returns the bearing but can’t tell if I am just stretching the spring (it takes a lot of force to go further) or if it is touching the fingers.
It currently grabs about 1 inch off the floor and in my opinion is too low.
What do you guys do?
nhusa is offline   Reply With Quote
Old 06-03-2018, 07:15 PM   #2
wmws
Default Re: Clutch adjustment
If you take the little cover off the bell housing you can see the trough out bearing and exactly what is going on.
wmws is offline   Reply With Quote
Old 06-04-2018, 09:28 AM   #3
daveymc29
daveymc29's Avatar
WMWS x 2 If you take that cover off and run the engine in neutral you should not see the throw out bearing spinning. It may turn slowly but should not be spinning at engine speed. I like the clutch low but it seems to me you may be a bit too low. Back off a turn and see how you like it.
daveymc29 is offline   Reply With Quote
Old 06-04-2018, 11:37 AM   #4
1931 flamingo
1931 flamingo's Avatar
Did you ck the finger adj on the p/plate when assembling??
Paul in CT
