10-28-2019, 09:01 AM | #1 |
Part numbers for F1 wheel bearings
I'm using F1 hubs on passenger spindles. I have the bearings and seals but I put the inner and outer races somewhere where they wouldn't get lost. Guess what. I can't find them now. They'd be the 1201 and 1217 parts I think.
Also, I looked at a couple of vendors and I couldn't find the 351153-S and 34814-S nut and washer for the pitman arm (for an F1 steering box.) Anyone know who might list them? Thanks!
10-28-2019, 09:08 AM | #2 |
Re: Part numbers for F1 wheel bearings
The inner bearing needs to be modified to fit. I believe that speedway sells the bearing already modified, but I find it cheap and easy to just do it yourself. It also allows you to select the bearing quality you want.
Inner bearing/seal: Bearing Timken 14116 Race Timken 14276 Seal Victor 49195 / National 450461 Outer bearing: Bearing Timken 09067 Race Timken 09195 Last edited by JSeery; 10-28-2019 at 09:27 AM. |
10-28-2019, 09:11 AM | #3 |
I will post the rest of the information if anyone is interested.
10-28-2019, 09:30 AM | #4 |
"Also, I looked at a couple of vendors and I couldn't find the 351153-S and 34814-S nut and washer for the pitman arm (for an F1 steering box.) Anyone know who might list them?"
Check with someone like Mac's or 3rd Generation. Also, might be able to get the parts off a junked steering box. |
10-28-2019, 09:41 AM | #5 |
Thanks so much. As soon as the weather goes bad I'll hop over to the semi-local bearing shop!
10-28-2019, 09:24 PM | #6 |
Their bearing kit also come loose in a plastic bag, not nicely boxed like Timken & National bearings, races, and seals. |
10-29-2019, 03:37 AM | #7 |
41 woodie https://41fordwoodie.weebly.com/ |
10-29-2019, 08:03 AM | #8 | |
10-29-2019, 01:36 PM | #9 |
All's well. I got the races from our local bearing supply house. I got the pitman arm nut and lock washer from the ACE Hardware. Size is 7/8=14 UNF. Thanks!
