02-29-2020, 01:38 PM | #21 |
Re: When going for SCAT crank should you lighten flywheel? If so, how much?
A heavy wheel helps on initial start of movement, after that it is mostly unnecessary. In the early years cars were still in the experimental stages, so small steps were taken. On a 1 cylinder engine, weight was needed to keep things turning, especially at slow speeds. A heavy wheel in our A's today may help on short hills, but on longer ones not so much as inertia of the wheel is static, but the speed of the car has changed, so it is a trade-off. A lighter wheel is better while accelerating and decelerating, so feels better from the drivers seat and once away from the stop sign, accelerates better. On such things as a hill climb, there is a big difference.
02-29-2020, 06:47 PM | #22 |
Slowing the engine with a 3.27 will store less energy so it will run out quicker on the hill. When you go to accelerate again the fly wheel will suck up a lot of energy again. That energy will be released in the future, but it may not be when you want it.
02-29-2020, 09:11 PM | #23 | |
Thanks. I guess I'll stick with a stock or a lightly lightened flywheel.
02-29-2020, 09:46 PM | #24 | |
These harmonic balancer pulleys sound interesting, especially for a high hp road car or a race engine, but are they worth the cost for a tour 50hp engine?
03-01-2020, 03:16 PM | #25 | |
Price including shipping is now 300 USD
03-02-2020, 12:35 AM | #26 |
If a crankshaft is hung with a string and tapped with a hammer, it will ring like a bell at its' natural frequency. When installed in a cylinder block, the crankshaft can ring at its' natural frequency at an RPM that is called "critical speed". Every rotating shaft (including a crankshaft) has a "critical speed". The critical speed occurs when the crankshaft rotates and has impulses (loads from power strokes [knock is very bad] or loads when the piston at TDC has to reverse direction) that coincide with the crankshafts' natural frequency. Critical speed can be felt as severe vibration at certain speeds. At critical speed, torsional deflections and stresses are at a maximum value and the cause of early fatigue failures. There are several ways to mitigate the problem and they include a stiffer crankshaft, additional main bearings for better support, a crankshaft material that has more damping, or the addition of a harmonic damper at the front of the crankshaft. Regarding the weight of a flywheel, weight is meaningless. What needs to be reduced is the polar moment of inertia. Google is your friend. Research "critical speed of crankshaft", "natural frequency", "harmonic damper", and "polar moment of inertia". |
03-06-2020, 04:37 PM | #27 |
what is the difference be twine the V8 clutch plate and the model a clutch plate
I've been doing so much for so long with so little that now I can do almost anything with nothing. |
03-12-2020, 02:36 PM | #28 |
03-12-2020, 05:23 PM | #29 |
Flywheel mass improves driveability by storing kinetic energy,a heavier flywheel shifts smoother,for example.There is a point of diminishing returns both ways,light and heavy..Ford used a heavy flywheel to dampen torsional impulse in the stock crank.Harmonic balancers work great,both cam gear chatter and pulley fracture gone,with a smoother running engine.I added one to maximize the life of a stock crankshaft,should work good with the counterbalanced crankshaft as well
