02-08-2019, 06:24 PM | #1 |
Replacing Stabilizer Bar Bushings on 1947 Ford
How does one go about replacing the stabilizer bar bushings (21A-5484) on a 1947 Ford ? Got the new bushings, but they seem too stiff, and the hole too small, to merely slide them over the ends of the stabilizer bar without the risk damaging them.
02-08-2019, 06:34 PM | #2 | |
Re: Replacing Stabilizer Bar Bushings on 1947 Ford
These bushings were originally placed on the bar prior to it being formed.
02-08-2019, 08:26 PM | #3 | |
In the future, I'll take it back apart and paint the bar. Good luck! |
02-08-2019, 08:35 PM | #4 |
Thanks Kube. Is the location of the cut important ? Perhaps the side so the shells pinch the cut closed ?
02-08-2019, 09:59 PM | #5 | |
Previous post says he got his on with some lubricant. I was never able to do that. You may be stronger than I and give it try before cutting.
02-09-2019, 06:39 AM | #6 |
02-09-2019, 07:56 AM | #7 |
The way I did mine was to make sure the bar was clean and smooth than with some grease pushed them in place but I like kubes40 idea about cutting them.
