11-03-2018, 04:05 PM | #1 |
33-34 and 35-36 coupe trunk hinges
Hi Guys:
If anyone would know, I figured it would be here: What are the differences between the two hinge assemblies, and can the 35-36 be adapted to a 34? The 34 hinges are very difficult to find right now, I figured if the 36 stuff would work it would widen my options. Thanks in advance guys, Dave |
11-03-2018, 07:47 PM | #2 |
Re: 33-34 and 35-36 coupe trunk hinges
I have no idea, but would be interested in the answer.
11-03-2018, 09:16 PM | #3 |
Oops! Thought you were talking about a sedan....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-03-2018 at 09:23 PM. |
11-04-2018, 06:12 PM | #4 |
I've just been going thru this, myself. From what I have found, the cast pivot blocks that mount on the body are the same between 33-34 and 35-36 coupe hinges But the "U" sharped cast pivot arms that fasten to the lids are a little different. The 33-34 pivot arms seem to be a little shorter between the lid mounting flange and the pivot point.
I do now have an extra set of 33-34 trunk hinges that I would consider doing some trading for the correct 35-36 trunk type. The 33-34 pivot arms usually have a readable visible "40" part number cast in them and The 35-36 type have a "48" number. |
11-04-2018, 08:57 PM | #5 |
There is a very good chance that repro hinges will be readily available early next year for the 1933-34, a bit later for 1935-36. |
