04-06-2017, 07:53 PM | #1 |
Body cart(dolly) plans wanted
Hi Barners,
Does anyone have or know where to find plans to built an adjustable steel body cart? Thanks in advance, Bruce/CT [email protected]
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
04-07-2017, 01:08 PM | #2 |
Re: Body cart(dolly) plans wanted
Not sure if it would help you or not, depending what car body you want to "cart" around. I have a frame out back I made with casters to roll a 34 coupe body around on. Pretty simple if you want a picture let me know.
04-07-2017, 01:13 PM | #3 |
Frame dimensions are available.
04-07-2017, 03:02 PM | #4 |
I got one of those metal frames that new four wheelers come in. Then cut the uprights to the height I wanted, added caster wheels to the bottom. With a sheet of plywood in top it makes a nice roll around work bench too!
04-07-2017, 06:59 PM | #5 |
Thnks for the replies.
I want it adjustable so I didn't put in that currently I'll use it for 196 Cabriolet. Bruce/CT
04-08-2017, 05:33 PM | #6 |
04-08-2017, 11:53 PM | #7 |
Hi; If you want to use it as a sand-blast or painting cart, it will need to be open to the floor pan bottom. Mine is two 'rails' on top of a frame with casters. Newc
04-09-2017, 09:27 AM | #8 |
The ones folks fabricate to install bare bodies in with roll over capabilities are set up like two engine stands facing each other with adjustable tie in tubes from one end to the other and heavy casters so they can be rolled. The bodies generally have to be cross braced if there is any flexibility to it at all and even if slight it's still a good idea to cross brace.
Each body can be so different that a person has to modify each time they use it for a different body. I've seen a few for sale but they are not cheap and some don't look heavy enough for my needs. A lot of work and material goes into their fabrication. Here is a link to an example. https://www.derekweaver.com/rodders-...FRyewAodbvYOZg |
04-10-2017, 09:08 PM | #9 |
Northern Tool has an adjustable truck bed cart for $219
PBE Adjustable Dually Dolly Truck Bed Dolly Item# 801500 Summit (part number SUM-906702) has a nice adjustable body cart for $399 that breaks down for storage: https://www.summitracing.com/parts/sum-906702 And a Similar one WMP-AT-BCC-A for $359. or Chassis dollies for $249 https://www.summitracing.com/parts/aaf-all10625 Good how to build article with pics and material needed: http://www.hotrod.com/articles/0804s...g-a-body-cart/ |
