Old 01-31-2018, 08:35 PM   #1
Bruce/CT
Default Engine test stand modification
Hi Barners,
I have an engine test stand that was designed to hold a Short Block Chevy engine (pardon me).
I need to rework all the mounts. What angle does the engine sit when fully mounted? I logically think that it should be level with the ground but just want to hear your opinions. I know the Ford 351 engine in my ski boat sits at 15 degrees....BUT that's a boat.
Thanks, Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 01-31-2018, 09:00 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Engine test stand modification
Go by the intake manifold carburetor flange. The carb base should be level to ground.
Old 01-31-2018, 09:19 PM   #3
Don
Don's Avatar
Had my 37 almost level and oil was coming out of vent hole in oil pan,using 4 qts oil,had to lower engine rear a full bubble with level on rear of bell housing,to keep oil from from coming out.
DON P
Don is offline   Reply With Quote
Old 02-01-2018, 09:36 PM   #4
Russ/40
Russ/40's Avatar
Something fishy going on there.
Old 02-01-2018, 11:51 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
My 8BA series engine has a ( 4° ) inclination.
Some earlier engines do not have any inclination built into the intake manifold so using the carb mount to set level could be in error.(the carb mount would not be level )
