Old 05-10-2010, 11:36 AM   #1
Newaygo Kid
Default Wide 5 balancing
Has any one used a wide 5 adapter from speedway motors to chuck up to a balancer and then bolt on your ford wide 5 wheel for balancing thanks Chris
Newaygo Kid is offline   Reply With Quote
Old 05-10-2010, 11:40 AM   #2
Pothole Jim
Pothole Jim's Avatar
Default Re: Wide 5 balancing
Think it would be easier and beneficial if you mounted the drum/hub/wheel/ tire assembly and balanced. Heard way to many stories about a balance issue that never went away until the balanced the hub/drum.
assembly
Pothole Jim is offline   Reply With Quote
Old 05-10-2010, 11:41 AM   #3
Ryan
Administrator
Ryan's Avatar
I've bought the adapter from Speedway just for balancing... Worked fine.
Ryan Cochran*
- www.AtomicIndustry.com
Ryan is offline   Reply With Quote
Old 05-10-2010, 11:43 AM   #4
37don
I put new Dimondbacks on the 37 last yr and used the Speedway adapter. We Checked the adapter by it's self first and it was good. All I can say is it worked for me, no out of balance problems in 3000mi.
Re3gards, Don
37don is offline   Reply With Quote
Old 05-10-2010, 03:55 PM   #5
franksford
Newyago kid, are you in Newyago mich? Frank in rockford Mich
franksford is offline   Reply With Quote
Old 05-10-2010, 04:05 PM   #6
Gary in Mozarks
Gary in Mozarks's Avatar
We had this discussion just before we switched to the new ford barn. Someone suggested taking your bearings and seal out and seeing if your local guy could balance the entire assembly. Im gonna try that. I may ask him to check the drum itself first then the entire assembly. Of coarse if its done that way you would want to mark your drum/wheel so if you ever removed the wheel you put it back in the same place.
Gary in Mozarks
Gary in Mozarks is offline   Reply With Quote
Old 05-10-2010, 08:09 PM   #7
Brendan
Brendan's Avatar
i just got tires for my 36 truck and two tire shops told me to bring in a drum , so that they can balance them, also i found a shop that still dose them on the car i still need to balance the tires
Brendan
Brendan is offline   Reply With Quote
Old 05-10-2010, 08:41 PM   #8
DICK SPADARO
Is this what you guys are looking for?
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 05-10-2010, 11:00 PM   #9
Brendan
Brendan's Avatar
where did you get that?
Old 05-10-2010, 11:36 PM   #10
harry jackshaft
harry jackshaft's Avatar
Brendan, were you planning on having those tires shaved round? If so, they are balanced while on the machine? It is unbelievable the difference it made.
"There is nothing good about a flathead, other than the fact that they are old" Dennis Kurimai
harry jackshaft is offline   Reply With Quote
Old 05-11-2010, 03:18 AM   #11
Brendan
Brendan's Avatar
actually they are a lot better then then the old tires, i saw a thread on the HAMB about a place in Napa that shaves tires.
Old 05-11-2010, 06:34 AM   #12
Newaygo Kid
Yes, Frank I am in croton michigan newaygo mailing adress, Chris
Old 05-11-2010, 06:55 AM   #13
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
It seems that it would be great to have the tires balanced on the car if one could find a tire store that still had the equipment.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-11-2010, 08:36 AM   #14
TomT/Williamsburg
TomT/Williamsburg's Avatar
When this was posted last time I also mentioned www.innovativebalancing.com - once the Dynabeads are installed, including using tubes, you never have to balance your tires again.
Someone asked about what happens when you get a flat - I did have one one e tubeless rim off the rear of my 40 coupe. I told the tire place of the beads but he was skeptical of the outcome and asked me to watch. Repaired the tire no problem using an inside patch and the beads just rolled off to the side.
TomT/Williamsburg is offline   Reply With Quote
Old 05-11-2010, 03:23 PM   #15
cvstl
cvstl's Avatar
I bought a speedway adapter just for balancing too. Make sure to buy the lug nuts, though.... they are oddball size. I had to use Nylock nuts from Fastenal to get mine balanced. Worked fine, but would have been easier with real lug nuts.
cvstl is offline   Reply With Quote
Old 05-11-2010, 03:56 PM   #16
Bruce Lancaster
An offer to the widefiveiacs: I made this offer a couple of years ago, never heard back from the taker...
I have a single wide 5 hub, rear from memory but my memory is nodamngood, with no drum...just the hub out to the lugs. It could presumably be spun and balanced and then would be a good adaptor for balancing your wheels, I think.
Utterly useless to me, free to a good home.
Pick up in NJ only, I am FAR too lazy to mail you the greasy lump.
Tell me if you want it, I'll leave it out on my front steps for you. Flourishing spider colony included, also FREE!!
Old 05-11-2010, 04:49 PM   #17
BILLF/TRF
BILLF/TRF's Avatar
I had a machine shop check the balance of the Speedway adapter and it was "right on". However the large nuts and bolts that attach it to the wide-five rim were up to .3 gram different from each other. You might look around for someone who would have an electronic balance (postal balance, high school or middle school) and grind them to equal each other since they may make a difference being so far from the center of the wheel.
BILLF/TRF is offline   Reply With Quote
Old 05-12-2010, 06:30 AM   #18
Newaygo Kid
Thanks, Bruce if I ever make out to NJ I will take you up on the offer thanks again Chris
