Old 02-24-2016, 12:55 PM   #1
Jwilli
Jwilli's Avatar
Default Are all A frames the same?
Will a model A frame work with any body style?
Jwilli is offline   Reply With Quote
Old 02-24-2016, 01:15 PM   #2
Rowdy
Default Re: Are all A frames the same?
Yes, but there were some differences in front crossmembers. Also many other changes. Most frames will work (although not correct) for most body styles. Late 31 cowl bolt holes were changed. Too many little changes to list here. If you are not a little detail person it might not matter to you. For me I like the details to match the time frame of the car. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-24-2016, 01:20 PM   #3
zzlegend
zzlegend's Avatar
Just beware of the front cross member. 28-29 versus 30-31 radiator mounts, if you want your hood to line up. Just my 2 cents.
zzlegend is offline   Reply With Quote
Old 02-24-2016, 01:34 PM   #4
darrylkmc
darrylkmc's Avatar
Everything you ever want to know about frames:
Steve Plucker
The Frame - Evolution of the Model A Frame
http://www.plucks329s.org/frame.htm
Darryl in a way too warm Fairbanks
darrylkmc is offline   Reply With Quote
Old 02-24-2016, 01:56 PM   #5
Jwilli
Jwilli's Avatar
Thanks for the replies, you can always count on some barner sharing the info you need.
Old 02-24-2016, 03:50 PM   #6
mramc1
mramc1's Avatar
I was surprised that I have frames with both RH steering hole and one without. Most I have seen have steering box hole on both sides?
Josh Quick
Quick Speed Shop
"6.50 rubber really gives you the old dig when you need it!"
mramc1 is offline   Reply With Quote
Old 02-24-2016, 04:02 PM   #7
mramc1
mramc1's Avatar
Figured it out. The frame I have with no RH hole is a Feb 1930 frame. Hole was removed January 1930. Makes sense now. Thanks to Steve Plucker The Frame - Evolution of the Model A Frame
for the info.
Josh Quick
Quick Speed Shop
Old 02-24-2016, 04:23 PM   #8
pooch
pooch's Avatar
Must have taken Henry a while to figure out if the scrap slugs being thrown back into the melting pot was worth more or less than the punching of the holes....
pooch is offline   Reply With Quote
Old 02-24-2016, 04:35 PM   #9
southfork
southfork's Avatar
There's an extra body mounting bracket on either side (towards the rear) of a late Frame that I have. Still not absolutely sure what Ford needed that extra bolt-down bracket for. Maybe for a Victoria or a Deluxe Delivery body?
southfork is offline   Reply With Quote
Old 02-24-2016, 05:21 PM   #10
CarlG
CarlG's Avatar
Some are for one swing, others are for two or three swings:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-24-2016, 10:34 PM   #11
Fred K-OR
Fred K-OR's Avatar
One in every crowd!
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
