Old 03-07-2024, 05:46 PM   #21
Mike1291
Mike1291's Avatar
Default Re: Light Wire Harness Bucket Seized/Issues
Originally Posted by Wick View Post
I finally got around to making a video on the light switch,horn rod. This might help a bunch of folks that hate working on the light switch.
It's posted on my YouTube channel named. Hookemfair garage.
Wick, thanks for the recommendation. The video had exactly what I needed to know - the position of the spider in the different switch positions. Now that I know that straight up and down is off I can fit everything in like it should
Early 1931 Coupe
Member of the Little Rhody Model A Club (MAFCA & MARC)
Mike1291 is offline   Reply With Quote
Old 03-08-2024, 09:33 AM   #22
Badpuppy
In response to post #20 - My thinking is the switch control is within reach, the switch at the bottom keeps hot wires out of the column tube.
Old 03-08-2024, 10:36 AM   #23
katy
katy's Avatar
Re post # 20, probably economics, having the switch down there uses less wire.
Old 03-08-2024, 11:15 AM   #24
Rob Doe
Hello, a 3 year newbie here, but I've redone the light switch on our coupe. A lot of reading and research plus the physical efforts went in to the final solution. I think I can add some information of value to this thread for those that follow.
X2 on all of the above and Wick's Youtube video. All good and my experience encountered each piece of knowledge.
I resolved the issues by purchasing the expensive, made exactly to the Ford prints, light switch from Snyder's. You must buy the matching bale for the new correct switch. I bought an extra as they are not expensive:
LIGHT SWITCH BODY
Part # A-11655/67 | Model Year 28-31
Mounts on bottom of steering column. The light wire harness slips inside this unit to turn lights off and on. This is not the poor functioning import unit, this is a quality American made switch assembly made to the archive blueprints! Brass contacts are properly formed and housing is cad plated.
The black switch plate that the wires connect to for this accurate, original switch body is a thickness of .310-.315 if my memory serves me correctly. I purchased a new, correct thickness, switch plate from Tyree Harris:
Phone 804-556-5200.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
