Old 07-31-2018, 12:15 PM   #1
Smitty
Smitty's Avatar
Default Model A Main Bearing-Block and Babbitt Temps
Hello All,
I am sure this has been covered before but what are the recommended Babbitt and Block temperatures for pouring main bearings? I know that the Wilson literature recommends room temp but consensus with most people seems to be a pre-heated block.
Can extra Babbitt in the melting pot be re-heatd and used or is it a 1-shot deal?
As always "the devil is in the details"
Thanx, Steve
Smitty is offline   Reply With Quote
Old 07-31-2018, 02:04 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Model A Main Bearing-Block and Babbitt Temps
Steve, the reason you pre-heat is to cut back on the shrinkage as the babbitt cools. Arguably, pre-heating is not that crucial if peining is properly done with the freshly-poured babbitt however I do both.
Yes, you can re-use the 'extra' however I think the size of the melting pot dictates that as crotched or overheated material is never good to re-use.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-01-2018, 07:17 PM   #3
Mark in MT
Another good reason to pre-heat the block is to get rid of any moisture, if hot Babbitt hits any water, it will explode and stick Babbitt to the ceiling. Don't ask me how I know.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 08-01-2018, 09:22 PM   #4
Kohnke Rebabbitting
I seen a Ford movie clip of Ford workmen pouring one block, after another.
1. Two Guys would put a block on the ground, and they were out side, in warm weather.
2. Two Guys would drop the 3 main Jig on.
3. One Guy had a torch like they sell up town, I have one, it is about 3 feet long with a 6 inch pipe on the end, with an I.D. of about 3 inches. It is NOT used for Babbitt!
K.R. Wilson said that Ford did not pre heat their blocks, BUT yes he did ! He just didn't use it as a step ! What was done was the jig was put on the block, and then this Jig was heated on the block, a bearing at a time. With this big torch, there is no way they heated the Jig, with out heating the block, but they didn't use preheat, as a step !
4. When heated, two Guys with two ladles each poured the block.
5. When, solid, two Guys pulled the Jig.
6. Then two Guys moved the block.
The purpose for heating a block, has nothing at all to do with shrinkage.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 08-02-2018, 12:08 AM   #5
Smitty
Smitty's Avatar
750 deg. on babbitt, 350 deg. on the block work? What can be used to stir hot babbitt if not a pine stick?
Thanx, Steve
Old 08-02-2018, 12:07 PM   #6
Kohnke Rebabbitting
Thanx, Steve
We have regulated pots. The Tinning pot holds about 3 gallon, of Babbitt, and the pouring pot holds about 5 gallon. The tinning pot is set from 610, to 640. The pouring pot runs at 950.
What most people don't know is, a Pine Stick was used on " LEAD BABBITT ONLY ". Long before the right Temperature for pouring Tin Base Babbitt, a pine stick will explode in to flame.
Herm.
