Old 06-21-2017, 10:26 PM   #21
kippmw
kippmw's Avatar
Default Re: Clutch issues...
Sorry, should've just posted the pictures in this thread.
The center hub of the clutch disc came apart and the pressure plate fingers were contacting the disc
1929 Briggs Fordor 165B
1930 Deluxe Coupe
1966 Mustang
2015 Ford Focus ST
kippmw is offline   Reply With Quote
Old 06-22-2017, 06:47 AM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
I would save the disc and take it to a clutch and drivetrain shop to have them rivet the center and replace the arms.
If they can't do that, then save the linings to rivet to a worn disc.
Old 06-22-2017, 08:54 AM   #23
SeaSlugs
SeaSlugs's Avatar
I bet the labor they would charge would be more than the cost of a new disc.
place I found that can rivet brake linings charges a shop rate of $90 an hour....
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-22-2017, 09:25 AM   #24
kippmw
kippmw's Avatar
Yeah, I went down to Bert's yesterday and picked up a pressure plate, disc and throw out bearing for under $200, so it might not be worth it to have the old parts fixed. I'll probably keep them as conversation pieces, though!
1930 Deluxe Coupe
1966 Mustang
2015 Ford Focus ST
Old 06-22-2017, 09:56 AM   #25
Tom Wesenberg
Save the clutch lining at least. I bought some new clutch linings from Rainmaker Ron just before he sold his business, and I will rivet them to used discs with worn linings. It's no different than riveting brake shoe linings.
