12-29-2016, 11:49 AM | #1 |
1913 magneto testing
I have the head off my 13 motor and was wondering can I test the magneto with only turning the engine over by hand cranking? Thanks guys
12-29-2016, 05:02 PM | #2 |
Re: 1913 magneto testing
Sort of not really. You would need to crank it over at around 60 RPM to get any real juice out of it. At hand crank/start speed it's hard enough to hear the coil buzz anyway.
I know the voices aren't real but damn they have some good ideas! |
12-29-2016, 05:38 PM | #3 |
Actually, if you happen to have one of these you can - http://www.funprojects.com/products/MT-1.aspx - this is a copy - I have an original and all one needs to do is a single 1/4 pull to see if the needle registers - has both scales for the early thinner magnets and the later 3/4" ones too - great tool !
12-29-2016, 09:45 PM | #4 |
THANKS I looked at the tester. Seems like that's what I need.
01-01-2017, 04:55 PM | #5 |
http://www.mtfca.com/discus/messages...152-332508.pdf |
