01-21-2015, 01:11 PM | #41 |
Re: How to: Jet flow test?
The set up I use is basically like the one in # 18 using the 36" column. When I got my flow tested jets from Renner's I tested them on my set up, And got the same reading that Renner's got.
01-21-2015, 01:17 PM | #42 | ||
Note that on the top of my test column there is a “T” that vents upward and provides a connection to the overflow tube. The 36 inch measurement is from the centerline of the overflow to the centerline of the test port.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 01-21-2015 at 03:52 PM. Reason: clarified that the overflow will create a syphon |
01-21-2015, 01:20 PM | #43 | |
Sounds good Ron. Was there something about my posts that lead you to believe that I did not already understand what you said above? |
01-21-2015, 03:46 PM | #44 |
I'm sure that everyone knows that the 36-inch height must be from the water level at the top to the tip of the jet (which might be different from where the flexible tubing comes out of the apparatus). If your apparatus provides the 36 inches and the tip of the jet is below where the flexible tube joins it, your reading will be too high. The reading will be too low if the tip of the jet is higher than 36-inch exit location.
I use an electronic scale to measure the amount of water flowed in one minute. It is safe to assume that 1 gram of water is equal to 1 ml or 1 cc of water. This method is much more accurate than what you can read with even with a chemist's graduated cylinder. |
01-21-2015, 04:13 PM | #45 | |
If it was required to get the flow to an exact individual number then I guess we'd all need an electronic scale. But, only to be within a "range" is required. A chemist's graduated cylinder is plenty accurate if one knows how to read the meniscus line. On my test stand, the test port and the jet installed stand straight out or in other words at a right angle to the tube. |
01-21-2015, 05:32 PM | #46 |
01-21-2015, 06:36 PM | #47 |
I don't know that, but my Rex Reheis carburetor book references an Al Blatter article from Secrets Magazine, that said you can convert 37.25" flow data to a 36" column by multiplying by 0.983.
