Old 10-24-2021, 07:02 PM   #1
50FlatheadVert
50FlatheadVert's Avatar
Default 1950 Radiator Options
Instead of repairing my stock radiator, are the benefits of a 4-core (looking at a US Radiator from Shoebox Central) worth the extra money? I'm not so much concerned with the price as I am with the cost benefit. My focus is reliability which also has me thinking 12 volt swap.
2009 BMW 135i, 2017 GTI S, 1990 SSP Notch (SOLD), Other Foxbodies (SOLD)
50FlatheadVert is offline   Reply With Quote
Old 10-25-2021, 11:14 AM   #2
TJ
TJ's Avatar
Default Re: 1950 Radiator Options
Go with the new radiator. Repairing an old radiator is just that. You still have an old radiator unless you recore it. In today's world a recore job it almost the same cost or more than a new radiator.
Old 10-25-2021, 12:44 PM   #3
Ross F-1
Ross F-1's Avatar
Aluminum radiators are generally not repairable, brass ones are. I wouldn't think in your climate you'd need 4 cores.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-25-2021, 03:11 PM   #4
50FlatheadVert
good points...the US Radiators are copper and brass so that's good
it's very humid here...heat soak in any car is terrible during the hot months not that I'll be taking it out in peak sun...I need to get it on the road and be comfortable that cooling won't be an issue
Old 10-27-2021, 09:18 AM   #5
Gene1949
Gene1949's Avatar
I had considered a 4 core/recore also but was talked out of it by the shop that used to build my stock car radiators (one of which is sitting in our 69 BBC Camaro).
Their/his thinking has "evolved" into 3 core 5/8" tubes and more fins per inch. It's all about management of airflow and amount of time the coolant stays in tubes. A good overflow/expansion tank helps
I also used a Taurus 2 speed fan and shroud off a late '90s SVO, practically a bolt in. Switches in bottom tank of radiator feeding a 70s Volvo set of relays and circuit breakers.
Finally a Chev distributer and electronics using manifold vacuum for the vac advance. Using Bubba's curve (thankx Bubba).
Pulling the hills here outside of Las Vegas in 105 degree days it will run 200-205 and right back down on the thermostats (180) on the flat.
Gene1949 is offline   Reply With Quote
Old 10-27-2021, 09:30 AM   #6
50FlatheadVert
Geat info…i’ll need to talk to my shop guy…180-205 is very impressive thanks!
Old 02-12-2022, 10:13 PM   #7
msstring
I had mine rebuilt by Glenn-Ray Radiator in Wausau, WI. Very happy with the results.
Sent from my SM-G973U using Tapatalk
msstring is offline   Reply With Quote
Old 02-12-2022, 11:38 PM   #8
Shoebox
Shoebox's Avatar
I'm doing a 6 cyl to V8 conversion to my '51 Tudor and bought a 4 row Desert Cooler US Radiator from Shoebox Central, looks quality although not quite as thick as I would imagine, time will tell.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
