Old 08-02-2018, 07:35 AM   #1
Richard Lorenz
Default Compression pressure Model B Ford
Does anyone know what compression pressure to expect with a Model B 4-cylinder engine?
Richard Lorenz is offline   Reply With Quote
Old 08-02-2018, 09:17 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Compression pressure Model B Ford
100 lbs.
Old 08-02-2018, 10:08 AM   #3
ursus
The Model-B has only a 4.6 compression ratio, which is slightly higher than the Model A. Mine was never higher than 75-80 pounds, with an 0.060 overbore.
Old 08-02-2018, 11:48 AM   #4
emf
emf's Avatar
I have not checked my Model B in the roadster, but my Model A engine with a 5.5 Snyder head gets 95 lbs on all four...
Frank
emf is offline   Reply With Quote
Old 08-02-2018, 12:37 PM   #5
Bob Bidonde
Bob Bidonde's Avatar
Ballpark is 14.7 x 4.6 = 67.6 psig. Dynamic head from piston motion will make the pressure higher, so psig of 70 or more seems reasonable.
Bob Bidonde
Old 08-03-2018, 06:59 AM   #6
larry loyd
Mine is around 75 psi on all four. It is a 39 diamond block in great running condition.
larry loyd is offline   Reply With Quote
