10-06-2012, 06:17 AM | #1 |
36 5W coupe upholstery
Does anyone have some pictures or info or a web site that shows what the upholstery in the rumble seat looked like, especially the sides of the rumble compartment.
Was the floor carpeted? Was it open through to the front seat? I have the Early Ford Clubs book but it doesn't show it at all. robert1936 |
10-07-2012, 12:40 AM | #2 |
Re: 36 5W coupe upholstery
The rumber seat base and back were in a plain simulated leather, no pattern. The sides had fiberboard panels upholstered in the same material to match. The floor has a rubber mat in a pattern similar to the front mat.
The seat back lifted up on two "tee" hinges and was held up with the same bracket used to hold up the trunk in the coupe without the rumble. There was clear access to the rear from the front seat. |
10-07-2012, 08:30 AM | #3 |
Robert D exactly right .Also if you get the kit frMacs or L B one of the side panel has a pocket built in..The rear mat will be almost impossible to find..I made my own..Good luck
10-07-2012, 11:04 PM | #4 |
Thanks fellas, it is finally in the paint shop!!
robert1936 |
10-07-2012, 11:27 PM | #5 | |
John L
Just slightly abrasive |
10-08-2012, 03:32 AM | #6 | |
This is a stock 36 Five Window Coupe And this is how I modified my 35 Five Window |
10-08-2012, 04:13 AM | #7 |
Here are two websites that offer for sale the rumble seat floor mats:
http://www.littledearborn.com/passen...floor__rum.htm http://www.cgfordparts.com/wwwsectio...t1_rumble.html |
10-08-2012, 10:17 AM | #8 |
Sorry guys. Mine is a Roadster. Forgot to put my brain in gear before I let out the clutch
John L
10-09-2012, 02:36 AM | #9 |
Robert1936, here are photos of my 1934 Ford rumble area. I hope they are clear enough for you to see them. This is maybe at least close to the 1936 but I am not sure as I have never seen a 1936 rumble up close.
The passenger side has a trap door sort of deal that locks. I was told it was called a "pistol pocket". The driver side has an open shelf area. The floor mat is dirty but in time I will be re-doing the whole car so they should be getting a good cleaning then. |
10-09-2012, 02:04 PM | #10 |
I'm pretty sure '36 didn't have that trap door.
Obsessed with all things 1936 Ford since birth... thanks Dad. |
10-09-2012, 02:38 PM | #11 |
I too wondered about that. It sure looks handy though but maybe better if it were bucket seats that had separate backs. Then you could actually switch places while driving from one passenger compartment to the other. Hmmm... I might have to work on that idea...
10-10-2012, 05:20 AM | #12 |
Thanks again for all the info.
Dave D, is that Benton grey or Russet brown on your steering column. |
