11-04-2019, 06:10 PM | #1 |
Engine Tag Codes - '65-'67 Mercury 410
I'm trying to find the 3-number engine identification code that's stamped on metal engine ID tags for the M-code 410 cu.in.-4v Mercury FE-series engine (not to be confused with the MEL-series 410 from '58-'60). Typically this code is on the bottom line of the metal tag that's bolted to the engine near the front of the intake manifold by the distributor. I have codes for 390s, 427s and 428s, but not the 410 .
Kultulz?
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
11-04-2019, 11:13 PM | #2 |
Re: Engine Tag Codes - '65-'67 Mercury 410
Find below -
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
11-05-2019, 10:32 AM | #3 |
Merci' Kultulz. I'm assuming the "M" is for manual transmission and that the letter/VIN code for both the US-only 2v/manual and the Canadian-only 4v are both "M" like the others.
Will have a separate message related to '65-'66 Mercury 390 codes shortly.
11-05-2019, 12:10 PM | #4 | |
The THREE DIGIT ID CODE only references the engine to the MPC for component service parts. TRANS/REAR ID will be found on the PATENT PLATE For further ENGINE BUILD INFO, you would start with the appropriate model year SHOP MANUAL No BRITE ROCKER COVERS-TRIM came through unless Special Order.
