08-06-2018, 04:15 PM | #1 |
Removing pulley & fan from waterpump on 226G SIX Cylinder
Ok.. I've read several posts on here about removing rusty items & freeing stuck motors using a combination of Marvel Mystery Oil, Automatic Trans Fluid, etc...
I removed the 4 bolts holding the fan & fan pulley to the water pump of my 1947 Ford Fordor with the flathead SIX motor (G model).. This is an extra pump, fan & pulley I bought as a spare (one of the rare items for this engine). It was sitting on a car in Montana for God knows how long.. I soaked the pulley & fan in AT fluid for the last two days after spraying some PB Blaster as well.. As you can see from the photos, I am soaking the bowl side of the pulley where it meets the flange on the water pump.. The 4 bolts are reinserted on the fan loosely to keep the AT fluid/PB Blaster juice from pouring out (instead it is trickling very, very slowly through the gaps & spreading out into the flange, fan & pulley.. I tried knocking the fan & pulley loose with a rubber mallet.. but so far no luck.. Should I soak longer? And suggestions would be helpful.. (no I am not planning on swapping the motor for an SBC..) Thanks WALT
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
08-06-2018, 09:53 PM | #2 |
Re: Removing pulley & fan from waterpump on 226G SIX Cylinder
Set it up in a press and press the shaft and impeller out of all.
Bruce
Works good Lasts long time |
08-06-2018, 10:14 PM | #3 |
Don't think that will work. Best I remember from dealing with the G series 6 I had in my 47 is that it has to be pressed out the front but I think there is a snap ring that has to come out first so that means the Pulley has to come off. The first year of the G series was 41 and that water pump has a bushing like the V8 pumps. After that, 42-47, it has a bearing like the 8BA v8.
08-06-2018, 10:29 PM | #4 |
This is from Van Pelt's site.
Bob |
08-06-2018, 10:41 PM | #5 |
I would suggest the blue spanner, try heating the pulley and then quenching it in cold water too that may stop things sticking together so much.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
08-07-2018, 05:00 PM | #6 | |
I am going to keep soaking for a couple more days.. our weather in L.A. today..106 degrees!
