05-17-2019, 06:30 PM | #1 |
Vacuum oil/fluid extractors...
Looking @ the Topsider MVP and the Mityvac 7201, are any of you fellas using these to change your fluids, newer/older vehicles ect.
I'm getting tired of crawling under the vehicles, I have to get under there to grease things but any input would be great. |
05-17-2019, 06:42 PM | #2 |
Re: Vacuum oil/fluid extractors...
Don't remember the band & model numbers, but in my boating days that was the way it had to be done. Really couldn't get to the oil pan or drain plug.
05-17-2019, 07:41 PM | #3 |
I bought one of the green flow tool Liquivac ones a few years ago, and it works better than I even hoped. Sucks that oil out right now. Handle fell off right away, though, have to hook visegrips on it.
I never did try emptying a whole car crankcase with it, however. Use it on everything else and motorcycles. |
05-18-2019, 01:09 AM | #4 |
I cant see myself using a vacuum device for engine or transmission. I get a lot of satisfaction knowing that when it drains out with gravity it lets out all the fine particles and possible sludge.
05-18-2019, 01:21 AM | #5 |
Well... That really sucks.
Alan |
05-18-2019, 03:59 AM | #6 | |
https://www.fordbarn.com/forum/showthread.php?t=253773
05-20-2019, 05:39 PM | #7 |
I went with the Mityvac 7201, extract and dispense motor oil, transmission/differential, coolant and brake fluid. This will make tuneup service a lot easier now.
