05-14-2019, 05:06 PM | #1 |
Fuel filter
Hallo und guten Tag,
I had to renew the fuel lines today. While I am doing that, I noticed heavy pollution in the collecting canister. Therefore I sawn through the gas filter. It was very heavily polluted with rust particles although it was only 900 miles in operation. This as an indication of a possible source of interference in classic cars that have stood still for a long time. Conclusion: Large filter surface with micronik-paper and early frequent changes.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
05-15-2019, 09:58 AM | #2 |
Re: Fuel filter
You might try a filter with a clear outer shell:
05-15-2019, 10:19 AM | #3 |
Re: Fuel filter
If using one of the above make sure it is an automotive filter. Do not use a cheap small engine filter - not enough flow. A friend had put in a small engine filter and wondered why his car started acting up - not getting enough gas at cruising speeds. If you have a glass sediment bowl there is an aftermarket micro filter that goes into the bowl and replaces the screen. Am not sure about the one shown above, but the micro filter traps the sediment on the inside of the filter, hard to tell when looking at the filter when it is in the bowl if it has filled up with crud. The in bowl micro filter in the picture was ordered from one of the Model A parts vendors, looked very expensive until I realized it said it was a set, and you actually get 2 filters for the price. |
05-15-2019, 10:38 AM | #4 |
Re: Fuel filter
I use the WIX 33039 or NAPA 3039 fuel filter. It looks similar (same) as the filter 30 Closed Cab PU suggests.
05-15-2019, 11:13 AM | #5 |
Re: Fuel filter
I always use the stand up filter that fits into the cut off valve . This filter stands up in the bottom of the tank and is out of sight . I also prefer the original cast iron sediment bowl filter on the firewall .
05-15-2019, 12:25 PM | #6 |
Re: Fuel filter
05-15-2019, 12:48 PM | #7 |
Re: Fuel filter
Good Morning: Another possibility that some of us use is a big magnet in the fuel bowl. It will grab anything metallic coming out of the gas tank and you can easily see how much junk is in the fuel bowl and then take it off and clean it out. I have a second filter from a 55 Thunderbird much the same with in and out fuel line fittings and it also has a magnet in the glass bowl. It requires changing about every other time the one on the firewall requires changing...Ernie in Arizona
05-15-2019, 02:08 PM | #8 |
Re: Fuel filter
Hello everyone, I have taken now a big filter from modern Opel. It has a volume of 4 ounces. Optically painted old. It fits in a lot of dirt. The micronic accordion filter paper also restrains dust particle size.
I threw a handful of brass nuts into the tank. They scratch old rust and cover off. After 5000 ml I throw the filter away and build in something inconspicuous again.
05-16-2019, 01:33 PM | #9 |
Re: Fuel filter
Since nothing else in my engine compartment looks "normal" anyway, I went overboard and put one of these on my pickup. With this one, you can drain small amounts of fuel out of the bottom of the filter in order to see the condition of the fuel without having to break it open.
05-21-2019, 04:35 AM | #10 |
Re: Fuel filter
Hello, I have to correct my previous filter recommendation!
Due to the large black housing, the fuel filter heats up too much. This creates gas bubbles inside. As a result, the hot engine stops in idling when the car is holding few minutes. For restart the choke must be pulled. So I have now a small plastic filter built in again. Like the one shown by Katy above. I write this as an information to detect any errors.
05-21-2019, 09:53 AM | #11 |
Re: Fuel filter
Werner, I think the slope of the filter in your picture (post #8) is wrong, I think the inlet should be higher than the outlet so that any bubbles will migrate away from the carburetor.
05-21-2019, 11:26 AM | #12 |
Re: Fuel filter
Good afternoon Katy, that's a good thought again! I had specially formed a S-bow so that no gas bubble in the filter can stay inside.
You recommend it is better a short lead diagonally down to the carburetor inlet? Like as on the painting?
