06-20-2022, 03:11 PM | #1 |
1938 Ford hand crank start
What tool would be used to hand crank start a 1938 Ford. Are they available to purchase? Thanks
Terry |
06-20-2022, 05:22 PM | #2 |
Re: 1938 Ford hand crank start
I think the factory lug wrench had an extension that would engage the ratchet nut on the end of the crankshaft.
However, have you looked at how well or how poorly the hole in the grill and clearance under the radiator line up for a crank? Also, the grill on a 38 is not particularly strong and would likely get damaged during crank starting. Many old cars theoretically have provision for hand cranking, but realistically push starting is the only option without damaging your grill. |
06-20-2022, 05:24 PM | #3 | |
06-20-2022, 08:56 PM | #4 |
4 Sure
06-20-2022, 09:15 PM | #5 |
Growing up on a farm and cranking lots of battery dead Allis Chalmers 4 cylinder engines. I think Henry would not let go of the concept. Was it a good idea? I don't think so?? But I have never tried it.
Get a crank and try it. Don't put your thumb around the crank. Just my two cents. Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
06-20-2022, 09:43 PM | #6 |
06-20-2022, 11:34 PM | #7 |
I sold my 38 std, cant remember but I am sure Henry did not design it to use the grill for the crank guide. There must be a more sturdy guide underneath. I have a crank start B Allis , an ott 9 Maxwell, several model T's, A's, and crank starting is not a problem, its a part of life
06-21-2022, 12:29 AM | #8 |
I'm impressed by you guys that grew up on a farm and have experience hand cranking engines. I've never done it in my life. I'd like to experience that. But also a bit afraid I would break my wrist or something. Maybe some day someone with a model T will walk me thru it, show me the safety procedures, and let me try it.
06-21-2022, 02:03 AM | #9 |
My go to after my '37 has been in hibernation.
06-21-2022, 04:31 AM | #10 |
Here is another way to get hurt. My buddy's dad would turn his front tire to the curb, jack up the driver side rear tire. Putting it high gear he used the tire to turn over the motor until it caught.
Enjoy yer day. Tom Hate can't fix what it started. |
06-21-2022, 08:33 AM | #11 |
My '36 has a hand crank and I used to start the car this way just for the fun of it. It always worked well for me. terry
06-21-2022, 01:24 PM | #12 |
In 1st gear, clutch in, ignition on, get it just barely rolling, pop the clutch, goose the foot feed, clutch in again, goose goose roar!
Alan |
06-23-2022, 07:20 AM | #13 |
Two quick rules...
1) as mentioned above--Never wrap your thumb around the crank handle. 2) Never spin the engine. Always pull up ONLY--never push down. |
06-23-2022, 08:46 AM | #14 |
