Old 03-30-2019, 08:08 AM   #1
jimvette59
jimvette59's Avatar
Default Howell's Panel above deck lid 27 roadster
Has any Barner used Howell's panel above the deck lid on a 26 27 Ford roadster ? How can it be made to fit . Really only wanted a skin and i got this heavy piece with no curve to fit into the back of the seat pan or curve at the deck lid. Any suggestions are appreciated. Thanks Jim T.
jimvette59 is offline   Reply With Quote
Old 03-30-2019, 10:29 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Howell's Panel above deck lid 27 roadster
It almost would have been easier to start from scratch. The only suggestion I have is to start shrinking that top flange and see if it will pull a curve into it without narrowing it down too much. Another alternative is to carefully cut the flange at the bend line and fabricate one with the curve needed then weld it back together.
That's a lot of work for something that should have fit from the get go. They didn't do anyone any favors.
Old 03-30-2019, 12:09 PM   #3
jimvette59
jimvette59's Avatar
The gauge of the steel is to much for my shrinker and I don't think it will pull a curve against the concave of the piece itself. Thank you for your information I am taking all suggestions into account at this time. I have repeatedly called and emailed Ryan but he refuses to answer my calls or emails. I asked him to send a Return Order and a Pre Paid Ups slip. I need to return this piece it is improperly made.
Old 05-03-2019, 01:42 PM   #4
jimvette59
jimvette59's Avatar
Default Re: Howells Panel above deck lid 27 roadster
They are there just to show the lack of curves. No they are not upside down.
Old 05-03-2019, 05:53 PM   #5
jimvette59
jimvette59's Avatar
I thru it in the scrap pile.
Old 05-04-2019, 08:42 AM   #6
zzlegend
zzlegend's Avatar
Welcome to Howell's. I bought a deck lid from them a few years ago. Did it fit? NOOOO. I had to open the upper and lower seams and rework it. After a few hours got it to fit. Painted it, installed it and then noticed the key hole. It was punched about an inch farther to the left instead of centered. Go figure. Also bought the panel below the deck lid and was surprised that it fit fairly decent. As for getting them on the phone? I think they are still using two tin cans and a string so it may take a while. Good luck Jim.
zzlegend is offline   Reply With Quote
Old 05-04-2019, 10:33 AM   #7
rotorwrench
A lot of stuff like that is out there from different sources and has been for a while. A person can try to make it fit by cutting it all up and wheeling or pounding in the proper shape then welding the proper shape flanges and edges on. A person that has the equipment can do it a lot easier by starting with a flat piece of new sheet metal. That eleminates cutting it all up and better quality sheet metal can be used. It's sad what some folks will try to pawn off now days. Make one crappy part and it shoots a reputation to hell. The best policy is don't try to sell something that isn't at least close to properly fitting. Let some other shmuck sell the crap.
Old 05-06-2019, 06:48 AM   #8
jimvette59
jimvette59's Avatar
That's why I thru a 200.00 piece in the scrap pile. I ordered directly from Howell's and spoke to him once then he cut me off. I should have ordered it on EBAY then I would have some recourse. Well hindsight is 20/20. Jim T.
Old 05-06-2019, 07:36 AM   #9
1ton
Seems the only solution would be to buy both the non curved panel to match the non curved decklid. Might as well get the lower panel too.
1ton is offline   Reply With Quote
Old 05-06-2019, 10:40 AM   #10
jimvette59
jimvette59's Avatar
I can't submit to these companies.
Old 05-07-2019, 02:59 PM   #11
dumb person
dumb person's Avatar
Ha. You threw it away?
I made my own. It doesn't matter much that the shrinker stretcher doesn't fit it. I've shrunk an edge by putting a claw hammer over the edge & giving it a twist. Hammer flat without making the "ting" noise. Do it several times (or several hundred)
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
