Old 01-10-2020, 01:41 PM   #1
burner31
burner31's Avatar
Default Welch plug for carb
Anyone know where I can get some Welch plugs?
In case you don't not know what these are, they are the little lead plugs installed at the factory to block off passages in the carb, they are a press fit.
Sometimes you have to remove these to clean the passages.
Found some online for .20 - .99 cents each, but shipping is $7, they must be crazier then me.
I'm running a Tilly by the way.
Anyway...anyone have any input?
Keith
Shawnee OK
'31 SW 160-B
Old 01-10-2020, 01:49 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Welch plug for carb
Have you considered using material from a roll of solder? The 50/50 or 60/40?
Old 01-10-2020, 01:52 PM   #3
burner31
burner31's Avatar
Was considering solder, but tapping in the correct plug would be so much better.
But may end up going that route.
Keith
Shawnee OK
'31 SW 160-B
Old 01-10-2020, 01:54 PM   #4
katy
katy's Avatar
If'n you use solder, make sure you use the type w/out a core.
Old 01-10-2020, 02:48 PM   #5
Bob C
The vendors have them. https://modelastore.com/fuel-system/...roduct_id=3996
Bob
Bob C is online now   Reply With Quote
Old 01-10-2020, 08:07 PM   #6
Mulletwagon
Mulletwagon's Avatar
Concur with the tap and plug route. Not for mass production but great for a one off.
Mulletwagon is offline   Reply With Quote
Old 01-10-2020, 10:46 PM   #7
redmodelt
redmodelt's Avatar
The are just plugs. The closest to welch plug would be the plug on the Tillys at the end of the throttle shaft. If they are solder, then someone must have been in there before, all the Zeniths I have seen are brass from the factory. I use the allen head set screws too. You can fill in the pocket as they get painted and no one but you will know.
Old 01-10-2020, 11:02 PM   #8
mike657894
mike657894's Avatar
Ive found one place carrying a plug for tilotson. About half way down page. I bought a box of carbs and need to get a few plugs. havent ordered yet. https://www.vintageford.com/sect_sea...b-%20Tillotson
mike657894 is offline   Reply With Quote
Old 01-10-2020, 11:05 PM   #9
daren007
Welch plugs are round soft dish plugs for closing core holes in blocks and heads which most people call freeze plugs. Incidentally blocks and heads will crack before these plugs are forced out. There are welch plugs in Carburetors as well.
daren007 is offline   Reply With Quote
Old 01-10-2020, 11:30 PM   #10
Brentwood Bob
I am also looking for the zenith throttle shaft brass welsh plug.
Brentwood Bob is offline   Reply With Quote
