Old 04-04-2013, 03:12 PM   #1
sphooch
sphooch's Avatar
Cool Brakes again - 31 roadster
HEY GUYS ONCE AGAIN I HAVE A BRAKE QUESTION ; rear drums are removed, left rear has shoes but no em. shoes installed and the drum goes back on with no problem. r rear , all brakes are installed , em . brake is on , I cannot get the drum to go back on, it goes on up to the first thread of the axle very tight. this drum needed to be pulled off with a puller. Any suggestions, is there a way to adjust the em. shoes so as to install the drum? ? . FIRST TIME WORKING ON MODEL A BRAKES . thanks again THE HOOCH
sphooch is offline   Reply With Quote
Old 04-04-2013, 03:23 PM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Brakes again - 31 roadster
Make sure your adjusters are all the way out, and you may have to sand the e-brake lining down a bit as the repop stuff can be too thick. Chamfer the shoe edges as well.
Good luck!
Farrell In Vancouver is offline   Reply With Quote
Old 04-04-2013, 04:51 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Also make sure the parking brake lever isn't part way pulled on and rusted in place. If it's rusted tight I'd use an oxy/acc torch to get the tube real hot then try to turn it. If you try to force it without heat there is a good chance of ruining the tight fit to the carrier plate.
