Old 09-24-2013, 02:35 PM   #1
Lowbuckboz
Lowbuckboz's Avatar
Default Spark plug connectors
Did the original spark plug connectors have "Ford" script embossed on them?
1927 T, 1930 A coupe, 1929 A Roadster, 1933 Dodge pickup, 1935 5 window coupe
Lowbuckboz is offline   Reply With Quote
Old 09-24-2013, 02:55 PM   #2
plind
plind's Avatar
Default Re: Spark plug connectors
I have a about 10 out of ca 20 where the " Ford " script are on.. So i will say yes..
www.forda1927.dk
Tudor * A 2820 *
Town Sedan * A 4472283 * Orig.never restored.
plind is offline   Reply With Quote
Old 09-24-2013, 02:58 PM   #3
Lowbuckboz
Lowbuckboz's Avatar
They are on my roadster. I was assuming they are original. A lot of original parts on this car. Seems to maybe be lower mileage and rather well kept. Thanks man!
Old 09-24-2013, 03:16 PM   #4
newshirt
newshirt's Avatar
The RG&JS don't mention a Ford script, so I'd like to hear more about this. Is their description incomplete? (See photo from the RG&JS below.)
Here's all they say:
The correct connectors from the distributor to spark plugs were stamped from 26 gauge bronze which had a copper color. From the beginning of production through May 1930 the connector ends were symmetrical (rather than offset). A new design was introduced in June 1930 in which the ends were offset (for more efficient use of bronze sheet stock). Both types were 3-1/8” from the center of the hole to the end of the prongs. The spark plug nut was round, knurled brass, 7/16” in diameter and 7/32” high.
More info here:
https://www.fordbarn.com/forum/showthread.php?t=92435
Ray White
newshirt is offline   Reply With Quote
Old 09-24-2013, 04:11 PM   #5
Lowbuckboz
Lowbuckboz's Avatar
I'd have to say its incomplete.
Old 09-24-2013, 06:08 PM   #6
Lowbuckboz
Lowbuckboz's Avatar
This is from my car. I also just noticed Ford script on the cap.
