09-16-2018, 01:06 AM | #1 |
8BA and 39 Trans
Newbie here trying to figure out this issue I’m having. I have a 8BA and a 39 transmission. I have the correct bellhousing. The trans mounts to engine with no issues. The problem I’m having is when I push the clutch pedal in the throw out bearing doesn’t contact the pressure plate. Pulled the motor to measure the clutch and pressure plate. It’s a 9 inch clutch. Do I have to run a bigger clutch and pressure plate set up. Any insight would be greatly appreciated.
09-16-2018, 08:14 AM | #2 |
Re: 8BA and 39 Trans
This would be answered better either on the EV8 Forum OR over on the HAMB.
Paul in CT |
09-16-2018, 11:16 AM | #3 |
A 9" should work fine. There were different throwout-bearing collars but I think V8's used the shortest one so that shouldn't be the problem, check that and the linkage anyway.
09-16-2018, 12:11 PM | #4 |
Throw out on backwards is that possible , how about fork Upside down .. Doesn't know if that possible . I had that concern as I was building me AV8 ....
"I can't cry as long as I know the Lord has risen " |
09-24-2018, 04:06 AM | #5 |
So the 9 inch clutch was the problem. I put a 10 inch clutch with the early style 10 spline hub and it worked
09-24-2018, 10:20 AM | #6 |
