04-13-2015, 09:50 AM | #1 |
Front Carpeting
The front carpeting in my Tudor is hard to keep in place and it's worn enough that I need to replace it. Although not correct for a Tudor Deluxe, I've been thinking about using a standard rubber mat replacement. Are there any pros or cons for either alternative?
04-13-2015, 09:58 AM | #2 |
Re: Front Carpeting
The carpet should be held in place by the fasteners, just like the rubber mat. It doesn't just "sit" there. Check the judging standards for details.
04-13-2015, 10:08 AM | #3 |
Re: Front Carpeting
If you use the fasteners your
Problem should be solved. Wayne |
04-13-2015, 01:21 PM | #4 |
Re: Front Carpeting
I believe the Tudor front carpet also had a fastener in each rear corner.
http://www.abarnyard.com/ |
04-13-2015, 03:59 PM | #5 | |
Re: Front Carpeting
Bill W.
04-13-2015, 04:47 PM | #6 |
Re: Front Carpeting
04-13-2015, 06:40 PM | #7 |
Re: Front Carpeting
My carpet is old but in fairly decent condition. I was thinking about adding an indoor/outdoor carpet as backing (---to make it stiffer,) gluing them together with contact cement. Do you think this would add another year or two to the life of the carpet? I think that it's too old for fasteners - especially where the corners are damaged.
