Old 11-08-2018, 04:35 PM   #1
whirnot
whirnot's Avatar
Default Do you polish your balls?
I pulled the steering column out of my 29 roadster and tore it down for overhaul. I am trying to make this thing as driver friendly as possible so my wife can drive it. I decided to look at all the steering joints as well, and was amazed how hard they were to turn. After tearing it all apart and cleaning everything, I ordered all my column parts, new arm rubbers, shortened Pitman Arm and a full set of teflon cups. The balls all looked pretty decent, one had a minor ridge that I was able to sand off pretty easily. But then I got to thinking since the goal is to decrease friction as much a possible, doesn't it make sense to polish the balls?
The steel is really relatively soft, and after a short time on the buffing wheel they look like chrome. Should make a huge difference in steering, and make the cups last longer.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-08-2018, 05:07 PM   #2
Stew Masche
Stew Masche's Avatar
Default Re: Do you polish your balls?
My bad !
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 11-08-2018, 05:09 PM   #3
FRANK PKNY
FRANK PKNY's Avatar
Boy that's a loaded question. Perhaps you need to clarify the question!
FRANK PKNY is offline   Reply With Quote
Old 11-08-2018, 05:10 PM   #4
Stew Masche
Be MECHANICALLY minded
Old 11-08-2018, 05:16 PM   #5
Bruce_MO
I’m waiting at an airport and don’t have access to what I need, but there’s a recommended value for maximum wear/out-of-round. Check with a cheap micrometer or caliper. If you’re beyond that value, polishing won’t likely help much. If you had a ridge, you’re probably beyond that max wear value. I had maybe one ball that was good and I chose to replace the others using A&L. The new ones looked great. I personally think all the binding is in the box design. I have a ‘32 with all the same tie rod end design as an A, but it steers a lot easier. Seems that folks choose to go with replacing the box with a early ‘50s F-1 box and love the results. Good luck
Bruce_MO is offline   Reply With Quote
Old 11-08-2018, 11:10 PM   #6
Tanglfoot
Only before I putt
Tanglfoot is offline   Reply With Quote
Old 11-09-2018, 06:43 AM   #7
updraught
updraught's Avatar
Originally Posted by Bruce_MO View Post
.... I personally think all the binding is in the box design. I have a ‘32 with all the same tie rod end design as an A, but it steers a lot easier. Seems that folks choose to go with replacing the box with a early ‘50s F-1 box and love the results. Good luck
I think the ratios are different on a 32 box (15:1?). I have a 29 two tooth RHD box with what seems to be 32 gears. I assume this was done for ratio improvement. Haven't tried it yet. Bought it on ebay.
updraught is offline   Reply With Quote
Old 11-09-2018, 08:53 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
Teflon cold flows under sustained / repeated loads, so I would not use Teflon ball socket parts. However, Teflon is an excellent lubricant, and I would seek a chassis grease that has Teflon particles in it.
The ball joint plugs preset a normal force on the ball joints, so it is important that the plugs are not too tight. I set the plugs in my Model "A" cars to compress the springs 0.06" which is one turn of the plugs after contacting the balls.
Front tire pressure also affects the steering effort. Higher pressure equates to easier steering, but a rougher ride. Toe-in also has a minor effect on the steering effort.
The webbing in the bushing at the top of the steering column is also a point of hi-friction, so lubricate the webbing too.
You need to explain to your wife that the steering is much easier when the Model "A" is moving even a little bit.
It would be fantastic if an entrepreneur in out hobby makes available a steering worm & sector ratio gear set which reduces the driver's steering effort.
Bob Bidonde
Old 11-09-2018, 09:28 AM   #9
ronn
I use Kiwi and try to stay away from black.........
Old 11-09-2018, 12:36 PM   #10
Jim Brierley
The shorter arm will help a lot. BTW, it's none of your !@#$%^ business what I do with my balls! -
Old 11-09-2018, 12:36 PM   #11
Flathead
Flathead's Avatar
The short aftermarket pitman arm eases steering effort.
Flathead is offline   Reply With Quote
Old 11-09-2018, 02:05 PM   #12
quickchange
quickchange's Avatar
Yes shorter pitman arm helps a lot & we produce a RHD one, As too polishing my balls , never tried that but do lubricate them often,
quickchange is offline   Reply With Quote
Old 11-10-2018, 02:10 AM   #13
Dodge
That'll make your little putter stand on end.....(Johnny Carson)
Dodge is offline   Reply With Quote
Old 11-10-2018, 09:10 AM   #14
old31
Yes, I remember that one. Arnold Palmer sued carson and won for his remark about his wife kissing his putter before Palmer goes out.
A very calm statement in today's times.
old31 is offline   Reply With Quote
Old 11-10-2018, 11:39 AM   #15
Cool Hand Lurker
Cool Hand Lurker's Avatar
I don't care what you do with your balls, polish them if you like, but I didn't know that a shorter arm was better. It does make sense though.
My gear is older so it has a lot of slop when I reverse direction.
Cool Hand Lurker is offline   Reply With Quote
Old 12-11-2018, 07:53 PM   #16
stillwater
Larry the Cable Guy shaved his once, for his lover. According to one of his skits.
Sounds a bit scary to me.
stillwater is offline   Reply With Quote
