Old 10-30-2019, 11:35 AM   #1
acstep
Default gas
what can you use to clean a gas tank of 15 year old gas, varnish.
acstep is offline   Reply With Quote
Old 10-30-2019, 11:37 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: gas
Fresh gasoline with 15% alcohol
Bob Bidonde
Old 10-30-2019, 12:00 PM   #3
dennis lumbert
dennis lumbert's Avatar
Default Re: gas
POR 15 cleaner/degreaser,(formally called marine clean)
dennis lumbert is offline   Reply With Quote
Old 10-30-2019, 12:13 PM   #4
rotorwrench
rotorwrench's Avatar
Default Re: gas
Drano crystals & water work but be careful mixing and handling. Sodium Hydroxide, or Lye for short, can burn you but it works really well to remove crap from a gas tank without hurting the metal.
Old 10-30-2019, 03:20 PM   #5
1929
Default Re: gas
I didn't find it difficult to just remove the whole tank, and clean it.
1929 is offline   Reply With Quote
Old 10-30-2019, 03:23 PM   #6
katy
katy's Avatar
Default Re: gas
If you splash any of that stuff on surfaces you don't want it on, the best thing to wash it off with is beer. It will neutralize the lye. How do I know? I worked in a brewery for 12 years and lye was used in the bottle washer. That was when most of the beer went into bottles, not cans.
Old 10-31-2019, 10:43 AM   #7
30 Closed Cab PU
Default Re: gas
When using lye or Drano, is a final flush of baking soda/water needed?
Old 10-31-2019, 12:44 PM   #8
J Franklin
J Franklin's Avatar
Default Re: gas
Lye is a Base chemical so baking soda won't help.
Old 10-31-2019, 02:04 PM   #9
rotorwrench
Default Re: gas
Lye would be diluted by fresh water rinsing. Water can be removed with alcohol, It can rust up with bare metal so it should be either put back into service or sealed to prevent corrosion unless it already has corrosion in there. Lye won't take the corrosion out. It's too bad that the terne plate doesn't last very well but that's what Ford used to seal them with.
