Old 10-06-2018, 03:12 PM   #1
hazelhoff
hazelhoff's Avatar
Default Wiring problem
Hi Guys, bought a harness from Brattons. One bulb, two tail, turn signal included, no cowl.
Turning the light switch on the wheel, the front two turn signals light up. Nothing else. Talil lichts OK, Horn OK, braking light OK. Nothing else ...
What could be the problem ? Does the switch have the notch upwards or downwards ?
hazelhoff is offline   Reply With Quote
Old 10-08-2018, 09:11 AM   #2
burner31
burner31's Avatar
Default Re: Wiring problem
Your spider gear is not aligned correctly.
Let me find the pic, and I'll send it to you.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-08-2018, 09:16 AM   #3
burner31
burner31's Avatar
Tabs on gear should be vertical, ensure switch is lined up right
Keith
Shawnee OK
'31 SW 160-B
