Old 05-04-2018, 12:40 PM   #1
Rob Needs
Rob Needs's Avatar
Default Front spring question.
Thanks Bob, pictures below.
Rob Needs is offline   Reply With Quote
Old 05-04-2018, 12:43 PM   #2
Floats
Floats's Avatar
Default Re: Test post transfer
OK, cheers, Chris
Floats is offline   Reply With Quote
Old 05-04-2018, 12:48 PM   #3
Rob Needs
Rob Needs's Avatar
On here
Old 05-04-2018, 01:54 PM   #4
wmws
Not sure where your coming from or want to go but maybe just copy and paste.
wmws is offline   Reply With Quote
Old 05-04-2018, 02:45 PM   #5
Bob C
How do those clamps come off, I'm getting new clamps and a new center bolt.
Can I just cut them off ?
And what do I need to do when they are striped down.
Like this??
Old 05-04-2018, 03:24 PM   #6
WHN
Default Re: Front spring question.
I hope your buying a new spring?
Good springs and shocks or needed for good handling and ride.
The one in the pictures is shoot.
Old 05-04-2018, 06:03 PM   #7
aermotor
Springs look to be in pretty good shape to me.
John
aermotor is offline   Reply With Quote
Old 05-04-2018, 06:56 PM   #8
redmodelt
redmodelt's Avatar
Guess there are 2 way; heat and bend the ears up (but you might change the temper of the steel leafs by time they are hot enough to bend) or cut and remove then replace with the style that uses thru bolt under leafs. Or just try prying them up.
Old 05-04-2018, 08:52 PM   #9
Step-down
Step-down's Avatar
hammaer and chisel , polish the leafs . Polish all the foot prints and polish the toe up so it does bind later.
Paint grease ,reassemble with clamp after you bolt the main back on your pearch . New bushing in all.
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 05-05-2018, 07:42 AM   #10
juke joint johnny
juke joint johnny's Avatar
They should measure 31 1/2" center of eye to center of eye.
If they are a lot more than that I would be tempted not to use them
juke joint johnny is offline   Reply With Quote
Old 05-05-2018, 08:40 AM   #11
Rob Needs
Rob Needs's Avatar
I have 31"
Old 05-05-2018, 09:09 AM   #12
Rob Needs
Rob Needs's Avatar
The springs have now been cleaned up, is it best to assemble them exactly the same order they came apart.
Old 05-05-2018, 09:36 AM   #13
aermotor
It's a must.
John
Old 05-05-2018, 11:31 AM   #14
WHN
If your planning on using your car as a driver and want it to be safe handling. Spend the money and buy a new spring. $130.00 to $220.00, depending on quality.
That spring has been on a car with weight on it for 90 years. It’s rusted badly, and you know what, it could break once you start driving.
There are some things that sanding and a coat of paint will not make like new. Springs are very important.
It’s time has come, replace it. One less thing to worry about. Enjoy.
Old 05-05-2018, 06:51 PM   #15
aermotor
Unless I could be 100% assured that a new spring was not made in China I would take my chances with a 90 year old spring.
John
Old 05-06-2018, 01:10 PM   #16
hardtimes
hardtimes's Avatar
Smile Re: Front spring question.
I have 31"
I agree with the 're-use' statements.
Especially, if is doesn't have any broken leafs and still measures 31", as you state.
Heck, if that were my spring, I would have started out with a much better one than was original to my '30 roadster....and it is still on the car and doing fine after some attn.
Also , if mine, and if you wanted to buy it....you'd have to pay extra for the 'patina' that has developed there over 80 years !
Old 05-07-2018, 03:15 PM   #17
Rob Needs
Rob Needs's Avatar
Great, after all the cleaning of the springs using a small angle grinder I've now got 'Popeye elbow'
Old 05-07-2018, 03:21 PM   #18
Will N
Will N's Avatar
Those clamps you have holding your leafs together are not original style. The originals were C shaped, fitted over the top of the leaf, and with the legs extending past the bottom. The legs have holes in them, and bolt goes across the bottom.
Will N is offline   Reply With Quote
Old 05-07-2018, 07:56 PM   #19
Step-down
Step-down's Avatar
A -Spring company in Hartford CT sells new USA made main leaf and build up from there with yours .....
Old 05-07-2018, 11:15 PM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I'm 82 5/12ths years Old & Folks still DEPEND on me! I have 7 1/2 DEPENDENTS! Can I claim them on my TAXES?
Bill Doe
"THE ASSISTANT GURU OF STUFF"
