05-05-2020, 11:27 PM | #1 |
hub face to hub face on 46 ford
what is the measurement from hub to hub on a 1946 ford rear end
05-05-2020, 11:31 PM | #2 |
Re: hub face to hub face on 46 ford
My list says 61"
05-05-2020, 11:32 PM | #3 |
car, truck, tonner? I could check the trucks tomorrow...
05-06-2020, 03:47 AM | #4 |
Mine says the same! DD 1928-1931 57.0″ Spring Mount Eye to Eye 49.5″ 1932-1934 57.75″ --------------------------- 47.5″ 1935-1936 59.5″ ----------------------------48.25″ 1937-1940 59.5″ -----------------------------48.5″ 1941 59.5"-------------------------------------46.75" 1942-1948 61.0″ -----------------------------46.75" Last edited by V8COOPMAN; 05-10-2020 at 01:35 AM. |
05-09-2020, 09:21 PM | #5 |
05-09-2020, 09:43 PM | #6 |
05-09-2020, 11:04 PM | #7 |
Is spring eye to spring eye the same as hub face to hub face? I don't see that....
05-09-2020, 11:18 PM | #8 |
jeez louise, gotta teach these green horns everything! hub face, as in axle flange face where the drum & wheel mount, no springs involved. there was a thread recently with an old magazine article with all the banjo axle widths, sorry gary, its late, and i'm too lazy to look it up for you, but you get the idea. hows the busted hand doing? hows the diesel doing?
05-10-2020, 01:37 AM | #9 | |
Look carefully at the RIGHT hand column in post #4......SPRING EYE measurements! DD |
05-10-2020, 09:25 AM | #10 | |
05-10-2020, 10:53 AM | #11 | |
05-10-2020, 11:18 AM | #12 |
Not sure why, but the StreetRodder article measurements are slightly different from the ones V8Coopman posted. Would guess it has to do with how you take the measurements. Here are the SR numbers if you can't read the chart in the scan.
The numbers are year(s)/Backing Plate Width/Outside Width/Spring Hanger Width 35-36 / 51.25 / 59.25 / 48.50 37-40 / 51.25 / 59.25 / 48.50 41 / 51.25 / 59.25 / 46.75 42-48 / 53.00 /61.00 / 46.75 |
05-10-2020, 03:56 PM | #13 |
Here's the Street Rodder article, full size. For future reference, it's posted on my V8 Club RG's website.
http://goldengatev8.org/images/Stree..._magazine.html
Alan |
