Old 01-22-2017, 10:08 AM   #1
coupeA31
Default 1935 ford pickup build
Hello from germany. I need some help to fix my emergency brake problems. My 35 pickup has a 59ab engine with a 50 mercury 3 speed transmission and hydraulic rear brakes installed. The rear brake cables comming out of the backing plates and ends with a clevis near the frame. Now I have to install everything to the front including a hand brake lever. Any idea what hand brake lever is the best for my tranny and what parts i need?
coupeA31 is offline   Reply With Quote
Old 01-22-2017, 10:11 AM   #2
Brendan
Brendan's Avatar
Default Re: 1935 ford pickup build
one thing i can say is welcome! and you need a trigger grip handle from a 37 ford
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-22-2017, 10:26 AM   #3
coupeA31
I have a handle from a 29 ford model a.
Old 01-22-2017, 10:36 AM   #4
coupeA31
Old 01-22-2017, 10:43 AM   #5
coupeA31
Old 01-22-2017, 10:52 AM   #6
coupeA31
Old 01-22-2017, 11:08 AM   #7
flatheadmurre
flatheadmurre's Avatar
Since you donīt have the original transmount with the attachment point for a emergency brake lever you have to manufacture some kind of bracket for it.
Old 01-22-2017, 12:58 PM   #8
raybee
I used a 37 PU handle in my 36 PU. Works good.
raybee is offline   Reply With Quote
Old 01-22-2017, 02:48 PM   #9
coupeA31
Ok, so I check some Ethernet sides to buy a handle.
Old 01-22-2017, 02:52 PM   #10
Lawson Cox
Lawson Cox's Avatar
This would probably be more appropriate over on the H.A.M.B
While on the subject of brake handles ,does anyone have an emergency brake handle extension for a 35-36 Ford pickup or passenger car that they will part with?
Old 01-22-2017, 04:08 PM   #11
GaryU.
GaryU.'s Avatar
Is this the handle needed or is the pickup mount different to what I believe is a passenger e-brake handle?
GaryU. is offline   Reply With Quote
Old 01-22-2017, 06:22 PM   #12
Scott H in Wheaton
Scott H in Wheaton's Avatar
I am going to try to adapt one of those handles to my 36 pickup, as I no longer have the brake rods that are activated by the other style.
Scott H in Wheaton is offline   Reply With Quote
Old 01-22-2017, 06:48 PM   #13
Jeff/Illinois
Jeff/Illinois's Avatar
Gary, that is what our '36 Pickup has, works fine I like it! Mounted under the dash of course on the left side of the steering column. That plus the starter button on the dash frees up your feet to hold in the clutch, brake, and give it a little gas.
Two good mods in my eyes.
Oh, and coupeA31, welcome buddy!! Keep us up to snuff on your pickup she looks like a nice one!!! Good luck you will find lots of good information here to help you.
Old 01-22-2017, 07:07 PM   #14
GaryU.
GaryU.'s Avatar
If anyone needs the e-brake handle let me know, just sitting in the basement with other parts that I will be using for my project.
Old 01-22-2017, 07:50 PM   #15
v8fordman
v8fordman's Avatar
I have both '37 pickup and passenger e-brake handles if you figure out which one you are going to use. Contact me at [email protected]
v8fordman is offline   Reply With Quote
Old 01-25-2017, 06:01 AM   #16
coupeA31
Gary, this is not the correct handle for a 35 pickup but i will try to use this. How much do you wont for it? [email protected]
Old 01-25-2017, 07:22 PM   #17
alanwoodieman
when hydraulic brakes were put on a 36 wagon that I worked on it had been converted to a 37 emergency brake release mounted to the left side of the dash with the proper cable running to the rear cable like was used on 39/40 cars
