01-29-2011, 10:33 PM | #1 |
H.a.m.b.
This cantankerous site is madding!! I have regestered twice and still cannot get it to take my password and user name that it agreed to. I guess that I will just let it slide and find something better to do!
01-29-2011, 10:39 PM | #2 |
Re: H.a.m.b.
You would be better off contacting Ryan to find out what your problem is, 'cause how our we supposed to help?
01-30-2011, 05:08 AM | #3 |
Re: H.a.m.b.
This is a pretty smart system. If you registered before, it will recognize your e-mail address. It is probably something that you are doing. I agree with v8 bob.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
01-30-2011, 06:01 AM | #4 |
Re: H.a.m.b.
I had "enrolled" once quite some time ago and forgot my password. I tried to sign "enroll" again using the same name and couldn't do it so I "enrolled" with a different name. Then, I remembered the lost password. Life is difficult. I only go on when I have a question that doesn't quite fit here on the Barn.
01-30-2011, 06:26 AM | #5 | |
Re: H.a.m.b.
Advice - if you can, try using your same name on both sites, for ease of use and to minimize having numerous names & passwords. It can be frustrating! Hope you get it sorted out. Ron |
01-30-2011, 07:03 AM | #6 |
Re: H.a.m.b.
01-30-2011, 07:11 AM | #7 |
Re: H.a.m.b.
You need a different password for the other site,and must be same letter caps,upper and lower case.
01-30-2011, 08:15 AM | #8 |
Re: H.a.m.b.
I use the same name and password on both sites.
John |
01-30-2011, 09:10 AM | #9 |
Re: H.a.m.b.
01-30-2011, 09:18 AM | #10 |
Re: H.a.m.b.
oldford2: NEATO!!!
Paul in CT |
01-30-2011, 10:39 AM | #11 |
Re: H.a.m.b.
Jerry....I was having the same problem on HAMB. When you enter your name and password, click on the remember me box and it should work. It does not automatically remember you the next time you use the site if you use the remember me if you log out.
01-30-2011, 12:48 PM | #12 |
Re: H.a.m.b.
Iv'e been trying for 2 days to reg on the hamb tried same one as barn & diff one with no luck if someone figures it out let me know-----thanks [email protected]
01-30-2011, 12:54 PM | #13 |
Re: H.a.m.b.
I had to reregister on the HAMB because I changed my email address... Lost all my old post, etc.
01-30-2011, 01:56 PM | #14 |
Re: H.a.m.b.
01-30-2011, 02:19 PM | #15 |
Re: H.a.m.b.
Oldandtired has it right on the money during the initial log in. I still have to re-do it every time my browser cooky file gets too full and I dellete the files. This makes it to where I have to re-log into all the different forums I look at.
Kerby |
01-30-2011, 02:42 PM | #16 |
Re: H.a.m.b.
oldford2,
What program are you using to change the colors on the pickup?
I've got the old car disease. Thankfully there's no cure! |
01-30-2011, 03:14 PM | #17 |
Re: H.a.m.b.
Steve, I am not that smart. I just copied a picture from the H.A.M.B. forum and pasted it over here. I believe it is from Photoshop. Sure would be handy trying to decide a color for your car. Maybe someone here knows about it. I will try and get details. John
01-30-2011, 03:53 PM | #18 |
Re: H.a.m.b.
Most likely done with Photoshop and a Gif animator but it's not just one program, it's a long process just like the way I made the rotating 'Flathead Ford Powered' emblem that you are using.
01-30-2011, 04:18 PM | #19 |
Re: H.a.m.b.
I have much the same thing, getting on the HAME, its the upper/lower case thing. my keyboard, I can't tell if its up or down, I haft to dig out an old keyboard,it lights on upper, so I know ... tryed several times, made it once or twice, for a us old geasers, this computer stuff is just to much or not worth the trouble, too much B-S,.... make it simple, ... I have 5 old HOT cams,( FLATHEAD ) I need specs. of A HOWARD M-8 and M-12, POTVIN 3/8 and unkowmn with flat top on the lobs, for longer duration ?? I am told the information is on the HAMB,,wish I could in and find out ..... OLD....BILL
.......MAYBE WE SHOULD ASK....WHAT ARE THEY HIDDING FROM ??? ....... |
01-30-2011, 04:18 PM | #20 |
Re: H.a.m.b. 51 merc ct
I am always impressed with what some of you guys do with some of the images posted. That is why I saved your image. Thanks. For those that want to see a good thread on Photoshop check this out:
http://www.jalopyjournal.com/forum/s...ight=photoshop Hope this works |
