Old 08-12-2019, 07:05 AM   #1
big job
big job's Avatar
Default Air shocks ?
I have been on the search for brackets etc. for rear air shocks from all the
usual vendors with no luck. And yes I know its a band aid but I don't have
the time plus the shop is plugged up with customer repairs. My car a 46
looks like its got 10 100 lb bags of cement. I can put three fingers between
the front fender and the tire and my rear is three fingers sagged. Not only
don't look good but being a tail dragger it effects front end caster too. So I
guess I'll have to fab up some kind of mounts. Has anyone done this? And
then Speedway has the proper spring kit but almost $1000 plus shipping for
1942 - 1948. Maybe a air bag between the rear end and the spring that
won't bother the axle myth back in the day we jacked 1,000s of these on
the center banjo with no harm done.... ideas?
big job is offline   Reply With Quote
Old 08-12-2019, 08:18 AM   #2
TJ
TJ's Avatar
Default Re: Air shocks ?
Pull the rear spring and go to a good spring shop. They can re-arch the rear spring for you. The other option is to look for a NOS rear spring.
Old 08-12-2019, 09:44 AM   #3
A bones
A bones's Avatar
I can say you must satisfy your need. One of my vehicles has air shocks. Just want to point out that while you can control ride height, you cannot ride comfort. Down is soft, up is hard.
Sorry I can't answer your question. Good Luck.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-12-2019, 03:35 PM   #4
1931 flamingo
1931 flamingo's Avatar
Do you have tube shocks on the rear now??
Paul in CT
Old 08-12-2019, 04:43 PM   #5
JSeery
JSeery's Avatar
I have run air shocks on cars I towed boats with. Worked ok, at the time there were not that expensive and easy to install. I also ran air bags on a new 67 mustang (to keep the body off of the slicks!). They were easy to install and not expensive.
Old 08-12-2019, 06:11 PM   #6
39portlander
39portlander's Avatar
This might help with some options, it's on my 39 P/U. I'm using NAPA 48785-L air shocks, what worked for me on this vehicle it probably was in an accident @ some point and some farm hand welded in some U channel stock for a rear cross member and mounting these was easy.
Routed the air lines up and over my fuel tank and have a fill schrader out the rear frame, last picture. There was a certain ride height I was trying to obtain based on the still height when parked.
I do have new Posi super slider rear springs and Bob Drake rear sway bar installed, hope this helps you out. Again on my truck this was a good option as the rear frame section from the bed back was modified from anything resembling stock.
39portlander is offline   Reply With Quote
Old 08-12-2019, 06:18 PM   #7
39portlander
ooop's
Old 08-12-2019, 06:21 PM   #8
40cpe
40cpe's Avatar
I see you have leafs removed from your rear spring. Was that for comfort or ride height?
Old 08-12-2019, 06:31 PM   #9
39portlander
There were 9 on the old spring and 9 on this new spring
Again, it was and old apple orchard farm truck rescued from VT, who know's what was done to it before I resurrected it. Put another hundred on it over the weekend, she puuurrr's like a kitten that's all that matters.
Old 08-12-2019, 07:12 PM   #10
Ggmac
You could add helper springs , they are coil springs about 4-5"" in dia and come in 3 diff load levels , should say over load weights . They have a bracket that mounts it on the axle tube and the top is resting under the frame the bottom mount has a u bolt that mounts to the axle tube .
I have a really old leaf spring helper also but I don't think it's available anymore . It was specifically made for transverse leaf springs and didn't require the spring to be removed .
Old 08-13-2019, 05:37 AM   #11
big job
big job's Avatar
All good ideas, I do not have tube shocks mine are original and work perfectly. TJ's
reply was my first though BUT around here the simple answer to that is 'gone' gone'
we had many truck /bus springs re arched U bolts made while I watched=radiator shops
all gone. Makes ya want to cry. Ggmac's reply I remember those. Again not looking for
load, just want to raise it up so it don't look like a DC 3 parked on the runway lol sam
Old 08-13-2019, 07:04 AM   #12
Ggmac
They do lift it . The load was to determine how much lift you need
Old 08-13-2019, 07:53 AM   #13
5851a
https://www.eatondetroitspring.com/ I used springs from here on a Bronco, Mustang and a Pinto Never had any problems. I tried adding air shocks and extra leaves, helper shocks over the years to various cars. By the time it was all done in every case I should have just saved my time and replaced the springs.
5851a is offline   Reply With Quote
Old 08-13-2019, 06:04 PM   #14
Ray Balukas
Ray Balukas's Avatar
Eaton Detroit springs are very good. replaced the front springs
on my 37 and am very happy with them. fit perfect and brought the front up 2" . talk to Gary at eaton, knows his stuff.
Ray Balukas is offline   Reply With Quote
Old 08-13-2019, 09:22 PM   #15
tubman
tubman's Avatar
I have also had good luck with Eaton-Detroit. I needed a spring built to fit the rear end of a hot rod I am building. I sent them the specifications and they returned a spring that was exactly right after a couple of weeks. The price was reasonable as well.
Old 08-13-2019, 09:27 PM   #16
JSeery
JSeery's Avatar
Any local spring shop should be able to build you a spring. Truck spring and axle type shops. I always just go to the shop and have it built, saves a lot of shipping! The last reversed eye main spring I had made ran about $25.
Old 08-14-2019, 07:04 AM   #17
big job
big job's Avatar
Don't I wish = spring shops are as rare as radiator shops around here
struts and air bags killed spring shops Aluminum radiators with plastic
tanks killed radiator shops, like button pushers are machinist now.
Old 08-14-2019, 08:16 AM   #18
JSeery
JSeery's Avatar
No idea about your area, but anywhere that works on large truck chassis should be able to fabricate springs. But then again maybe I'm just spoiled! I have been using the same spring and axle shop for almost 55 years, LOL. Man, all the radiator shops around here have disappeared.
Old 08-14-2019, 09:07 AM   #19
TJ
TJ's Avatar
Advertise on here and the V-8 Club website for a NOS rear spring. If no luck call Eaton-Detroit spring. They have a good reputation. Personally I would avoid the air shock fix.
Old 08-14-2019, 02:11 PM   #20
Seth Swoboda
Seth Swoboda's Avatar
I agree. The air shock is a band-aide. A nice original or NOS spring should be easily found. Put an ad here on the fordbarn for starters.
