Old 04-11-2024, 01:55 PM   #1
corvette8n
corvette8n's Avatar
Default Drove 30mi round trip burned 1qt oil
I could see the blue smoke in my rear view mirror. I’m currently running 20-50 racing oil. Compression is 60lbs for all 8 cylinders, this motor is tired. Should I switch to straight 40 or 50wt oil to get me through car show season? I will either get this motor rebuilt during winter or my other 90% complete one rebuilt.
Old 04-11-2024, 06:59 PM   #2
TJ
TJ's Avatar
Default Re: Drove 30mi round trip burned 1qt oil
Straight 40 wt. might help. Your are definitely ready for a rebuild. I've been there and done that with a '38 and burned a quart every 60 miles.
Old 04-11-2024, 10:35 PM   #3
cas3
I would just drive the heck out of it. Who knows, it may improve. Some marvels magic oil mixed in may even loosen up some stuck rings. drive it, it can't get worse!
Old 04-12-2024, 12:01 AM   #4
GB SISSON
GB SISSON's Avatar
And if it's plum wore out and Skip's spirited driving advice doesn't help, then I might suggest running a cocktail of equal amounts of GL4 90wt, STP (high mileage), John Deere Cornhead grease and Crisco. If the motor lasts into the fall, substitute a couple bottles of wesson oil for the crisco.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 04-12-2024, 07:19 AM   #5
cadillac512
cadillac512's Avatar
Originally Posted by gb sisson View Post
and if it's plum wore out and skip's spirited driving advice doesn't help, then i might suggest running a cocktail of equal amounts of gl4 90wt, stp (high mileage), john deere cornhead grease and crisco. If the motor lasts into the fall, substitute a couple bottles of wesson oil for the crisco.
I think Gary may be sampling his still. LOL!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is online now   Reply With Quote
Old 04-12-2024, 07:53 AM   #6
pistonbroke
Gary , Where were you with that advice two years ago when I was bombin around Olympia with my seven cylinder low to no compression 8ba. Instead of smelling burnt oil I would have smelled like any greasy spoon diner. LOL Tim
pistonbroke is offline   Reply With Quote
Old 04-12-2024, 08:35 AM   #7
GB SISSON
GB SISSON's Avatar
Nope... Left all that stuff behind on Aug 22, 2022. Never looked back, so I'll need to conjure up some other excuse. And Tim, the cooking grease helps cover the smell of burnt 90W. The main drawback to this 'cocktail' is that you need to have the engine running, fold in the new ingredients slowly while draining the old oil, then leave the engine running 24/7 or you'll never get it started again.
But seriously folks, in fairness to the OP, I would go with straight 50 wt from the cheapest source possible and a can of STP wouldn't hurt..
Old 04-12-2024, 01:03 PM   #8
cadillac512
If the OP goes with Gary's earlier cocktail I sure hope I'm not the one to get the rebuild job.
Old 04-12-2024, 01:21 PM   #9
rich b
rich b's Avatar
Don't they still sell that "ring job in a can" stuff down at Western Auto.
rich b is offline   Reply With Quote
