08-06-2018, 11:21 PM | #1 |
Steering shaft
Hello again need help to get a stuck key out of cylinder. Also what keeps clylinder in place came out with ease. Help would be appreciated. Thanks.
08-07-2018, 12:04 AM | #2 |
Re: Steering shaft
If it´s an early steering column lock you have a pin holding the cylinder in place.
Has to be drilled out. |
08-07-2018, 01:09 AM | #3 |
Re: Steering shaft
If the lock cylinder came out with ease you're half way home. If you can't get the key out of the cylinder.. is the key in place, but the knob broken off'
08-07-2018, 09:57 AM | #4 |
Re: Steering shaft
Key not broke off, just will not come out. Did not release any pins to get clylinder out
08-07-2018, 11:02 AM | #5 |
Re: Steering shaft
Try rotating it to the locked position. It may be oriented in the wrong position.
Hook |
08-07-2018, 11:20 AM | #6 |
Re: Steering shaft
